12-04-2014, 12:00 PM
#21
Plain and simple, replace it. Best insurance you can buy for 55 dollars. These have a very high premature failure rate. Ours lasted less than a year. Manufacturer and Forest River and dealer could care less to help. Just do it, replace it.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
12-04-2014, 12:01 PM
#22
Originally Posted by meck51
...You want a viable alternative. Send the unit to get calibrated, you know with a controlled environment and none of the variables.
Or better yet and much cheaper, just go buy a new unit. It's $20 and could save your families life.
I posted a much safer do-it-yourself test above. We can all agree using a car in a garage isn't safe.
As for getting your unit calibrated, what will that cost? $50? $100? Nobody will do that for a $20 piece of equipment.
So you go out and buy a new detector. You are back at square one because it is then UNTESTED. When I produce something new at work I then need to do unit testing on it, or I have no idea if it meets the requirements...
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
12-04-2014, 12:03 PM
#23
As I just posted, then you still need to test it. Old or new, you need to verify the sensor works.
2010 Chevy Suburban
12-04-2014, 12:42 PM
#24
Yes, you do need to test a new unit. That is why there is a test button. The test button sends a charge thru the sensor that in a manner that is above my head "simulates" the presence of CO. After the successful completion of this test (which takes mili seconds) the alarm will sound. If the test is not successful the alarm will not sound and the display should show an error code, this will vary from on brand to the next. I am comfortable with relying upon this test method as it is solely the purpose of the test button and the unit. It is the reason that the manufacture recommends the unit be "tested" weekly or monthly. In my trailer I hit the button as I am setting up shop as a force of habit, at home I do it with the kids once a month because it promotes good safety practices.
There is what is called calibration gas, which is typically a mixture of CO and nitrogen that you can test a unit with. However I have never seen it produced for a consumer level and I am fairly certain the cost would be prohibitive.
People can use what ever method they want, but IMO if you are going to conduct a test you should at least know what the pass/fail criteria is or you are just spinning your wheels.
12-04-2014, 02:42 PM
#25
Yes, you do need to test a new unit. That is why there is a test button. The test button sends a charge thru the sensor that in a manner that is above my head "simulates" the presence of CO.....If the test is not successful the alarm will not sound and the display should show an error code, this will vary from on brand to the next. I am comfortable with relying upon this test method as it is solely the purpose of the test button and the unit. It is the reason that the manufacture recommends the unit be "tested" weekly or monthly. In my trailer I hit the button as I am setting up shop as a force of habit, at home I do it with the kids once a month because it promotes good safety practices.
Both types of CO detectors in common use have a change in electrical current from the detector when the level of CO changes. The test button simulates this change in current through the alarm circuitry. It cannot test whether or not the detector is reacting (in part or at all) to the presence of CO.
Whether or not the detector/alarm produces time-averaged readings is a function of the electronics, not the detector element. The cheapest detector alarms do not time average or provide a CO concentration readout. They just alarm when the CO concentration crosses a pre-set threshold (assumes proper operation). Guess what type of CO/propane alarm my FR A-frame has. :-)
The only purpose of the CO detector/alarm is to provide early warning before CO levels reach dangerous concentrations. A false negative - rising CO levels are not detected/alarmed - can be fatal, especially with a known (assumed to be working) alarm present.
Given that CO detectors have inherently unknown but limited lifespans, and the number of electronic devices that don't work out of the box, you better believe that I'm going to verify my just-bought new detector will actually detect CO. Am I particularly concerned with whether or not the alarm set point is precisely 40ppm? No, nice to have, but not critical for the function. So long as the device responds promptly to dangerously elevated CO levels to give me early warning to get out of the house or RV, it's done its job.
I like the idea of an outside test much better than my garage test. I like even better using 2 detectors - one of which has a readout - to compare against each other when testing.
my thoughts, your choices
Fred W
12-05-2014, 04:57 PM
#27
A CO detector is a great idea for a camper (if it is not working replace it) Our current camper is the first one to have one. It is only the second one to have a smoke alarm.........
Our house does not have one & here do not see the need......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
12-05-2014, 05:06 PM
#28
Originally Posted by RamblerGuy
That's great but what are you doing about a Propane gas detector.
12-05-2014, 07:14 PM
#29
If you use a backup generator or have heating produced by a flame (gas/oil/wood), you should get a CO detector. I have 2.
2010 Chevy Suburban
12-05-2014, 10:49 PM
#30
Thanks, I know, we have none of those, so I have no need. The house is 100% electric.
1966 Mustang GT
1986 Mustang SVO
12-06-2014, 07:15 AM
#31
I've looked for a propane detector that is battery powered but it appears that they take too much power to have a useful battery life. I found one that runs on 120 volts with a battery backup and downloaded the manual, which stated that battery is good for about a day.
I will probably get a dedicated RV propane detector that that runs on 12 volts. At least I will have a more reliable CO detector. Unfortunately, I think the majority of false alarms have been by the LP side of the combined LP/CO detector, so I may not be making progress in that aspect.
Here's the web page for the explosive gas detector. You can download the manual there. It would be nice for your house if you have gas, or for your RV if you always have it plugged in. Just don't forget to remove the battery when you unplug.
Kidde KN-COEG-3 - Nighthawk AC Plug-in Operated Carbon Monoxide and Explosive Gas Alarm
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
12-06-2014, 07:33 AM
#32
I am not suggesting that you do not get a Propane detector but at least you can smell propane but you can not smell CO.
Does any one know how may years the detectors have been in RVs ? Not too many I don't think.
1966 Mustang GT
1986 Mustang SVO
12-06-2014, 07:51 AM
#33
You can smell propane before it reaches a explosive concentration, so you don't really need a propane detector most of the time. A propane detector is valuable when you are sleeping. Smells don't wake you up.
That said, as far as I know, propane/natural gas detectors are not required in homes and motels by codes as are smoke detectors.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
12-06-2014, 04:34 PM
#34
Depending upon the odor is a dangerous proposition. It is added at the point of distribution, as propane itself is odorless. The additive is called mercaptin. There are documented cases of propane being sold where the mercaptin wasn't added. Not worth the risk to me. I'd never be without one.
Bill & Beth
Hyde Park, NY
2014 Sportscoach Cross Country 405FK
2015 GMC Acadia
12-06-2014, 05:05 PM
#35
A problem that can occur with propane is the loss of odor. There are cases in which the odor has been thought to be diminished or plainly the people smelling the propane no longer smelt it, when in fact the persons ability to smell it has just been diminished. Thusly, the person thought there was no longer a leak when in fact there was and they just could not smell it anymore because their sense of smell was accustomed to the odor. This generally happens at higher concentrations or prolonged exposure. After removing yourself from the affected atmosphere for a while your senses go back to normal.
There have also been cases where the odor has been diminished thru bleeding out thru piping that has been contaminated with water or while passing thru soil.
02-17-2015, 08:34 PM
#36
I just bought a used motorhome and I am going over everything in it.
I did a search for testing CO detectors. While I was reading this thread it occurred to me: it is battery operated device, take it off the wall, go outside and hold it near the exhaust pipe of a running vehicle, dummy.
I do like that "10 year" model with the digital readout..
2007 Chevy Couchman Freeloader
02-18-2015, 12:36 PM
#37
Don't do that !!!! You'll kill the internal sensor and render the device useless.
Carbon Monoxide Alarm & Detector FAQs | FirstAlertStore.com
Read the section titled "Can I test my carbon monoxide alarm in any other way besides pressing the test button?"
Bill & Beth
Hyde Park, NY
2015 GMC Acadia
