Old 11-24-2014, 08:20 AM   #1
BuckeyeGal
Question CO Alarm???
During stay in near Beaufort SC CO alarm kept going off. No propane use. rained all day (2-3 inches); very humid, but not warm enough for A/C either. Have a 2012 Sabre 5th wheel. will high humidity set this off if too sensitive? Wife's hair spray has routinely set it off as well. Any chance that we have wore it out prematurely?
tvc
Terry & Carol
2012 Sabre 31-CKTS-6
2003 F-250CC 7.3L Powerstroke
buckeyegal is offline   Reply With Quote
Old 11-24-2014, 10:51 AM   #2
Mine lasted a little over two years then I couldn't get it to stop. Pulled the fuse, 3 AMP, and replaced it about $55 from Camping World and because I got the same one I didn't have to change bracket. Good Luck
whj77372 is offline   Reply With Quote
Old 11-24-2014, 12:19 PM   #3
Witch Doctor's Avatar
tvc
any thing can set it off. If your not using propane It just doesn't like what it smells. Put a switch on it to shut it off when not in use. It could be low battery to something outside. I don't think you wore it out. If your running your furnace it can be picking it up in the return air in your basement what ever you have stored down there.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-24-2014, 04:29 PM   #4
ALL of these posts are confusing - are you sure you aren't all talking about the LPG detector (talk about pullling fuses, hair spray etc)? Different beast from the CO detector. LPG detector will beep from low voltage, is wired in permanently via a fuse, and can be set off by hair spray, sewer gas, etc.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-24-2014, 04:50 PM   #5
Your correct techntrek, But I think the key word was when he mentioned propane and hair spay. But that is an assumption on my part which could make me the first 3 letters in assumption.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-24-2014, 09:29 PM   #6
WFD
And exactly what do you mean by it keeps going off? Is it a solid tone or is it a periodic chirp? The chirp is indicative of a low battery.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-25-2014, 07:50 AM   #7
Solid tone would be from the LPG detector, periodic chirp from a CO or smoke detector...
2010 Chevy Suburban
Old 11-25-2014, 04:32 PM   #8
Terier's Avatar
After my hair spray set off my alarm I started turning on the Fantastic Fan after wards. My alarm is near my bathroom so I aim the spray towards the shower wall while I'm facing the alarm. This allows the over spray to go away from the alarm.
Old 11-28-2014, 10:00 AM   #9
BuckeyeGal
Sorry for the confusion. We a combination LP & CO detector close to floor & the steps going to bath & bedroom. unit would sound off whenever my wife sprayed her hair. then it started going off in middle of night with no propane in use (no stove or furnace).
Terry & Carol
Old 11-28-2014, 11:38 AM   #10
onetonford's Avatar
Bad setup imho a propane detector should be mounted at the floor and a CO detector should be mounted higher at either ceiling or your nostrils height not lower. CO gas is lighter than air where propane gas is heaver than air. I would replace the bad detector with two one for propane at the floor and one for CO at the ceiling that is the way my fiver came from the factory. just my .02 cents worth.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
