Old 12-31-2015, 12:23 AM   #1
simplyrwc's Avatar
Condensation
Just wondering if anyone has had a condensation issue on the bed frame over the storage area and if so what did you do to prevent it?
I'm getting condensation between the mattress and the particle board bed frame.
I have a Wildwood 32bhds stored in a shop and utilizing to sleep in while remodeling the house, so running the heater while in the trailer. Thanks in advance for any responses.
simplyrwc is offline   Reply With Quote
Old 12-31-2015, 01:24 AM   #2
Buy a cheap dehumidifier on Amazon. You would be surprised at the amount of water it collects in a 24 hour period. Heater is fine but it won't do much for the humidity. Heater+dehumidifier is the way to go. We bought & have been happy with: Ivation GDM20 Thermo-Electric Dehumidifier. It was around $40.
BradB is offline   Reply With Quote
Old 12-31-2015, 02:05 AM   #3
Who Dares, Wins
doc73's Avatar
I have also heard a few people use the foam insulation board to make a better air gap between the hot mattress and cold storage area. I also second the dehumidifier.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-31-2015, 04:51 AM   #4
Are you calling the (Propane Furnace) the heater? Youroo!!
youroo is online now   Reply With Quote
Old 12-31-2015, 11:38 AM   #5
simplyrwc's Avatar
Yes the propane furnace...
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
Old 12-31-2015, 07:05 PM   #6
So you have a RV inside a Building and you are running a Propane Furnace,this is a (DEATH WISH)!! STOP This NOW! Youroo!!
Old 12-31-2015, 07:14 PM   #7
toslow's Avatar
statistics
haven a blast
toslow is offline   Reply With Quote
Old 12-31-2015, 07:19 PM   #8
Kenny kustom's Avatar
Popcorn
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-31-2015, 07:56 PM   #9
Oklahoma Proud
MillerTime's Avatar
Yep this could be really bad. Might as well run a vehicle in the shop....maybe a little safer than that...hope the doors are all open. Good luck op! I think condensation would be a moot point.
Old 12-31-2015, 08:11 PM   #10
Flybob's Avatar
The condensation under the mattress comes from the moisture from your body penetrating the mattress and condensing on the cold bed frame. You can add a 1/2" insulating foam board under the mattress or a moisture proof mattress cover. Also put a swimming pool noodle between the head of the mattress and the wall to allow the moisture to evaporate. You can also use a fan to circulate air and prevent moist spots.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
