Old 07-12-2019, 01:15 PM   #1
widogmom's Avatar
Condensation in bin next to LP tank - Sunseeker
Hi, folks. Our Sunseeker has condensation in the bin closest to the LP tank. It's the only bin with this problem, so I'm wondering if it has anything to do with the LP tank's proximity? It's also kind of kittycorner below the water heater, but it's one of those solid bins and I can't see anywhere that water would leak in. Any thoughts on this, and how I might remediate it? Thanks!
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 07-12-2019, 01:27 PM   #2
Check the door seal, mine had the gap at the top, it should be at the bottom. After a rain storm I noticed water inside the bin. I have since applied silicone sealant in the gap and have not had anymore water leaks in the bin
ddhansen is offline   Reply With Quote
Old 07-12-2019, 01:33 PM   #3
widogmom's Avatar
Thanks. I just checked it, the seal seam is on the bottom. Doesn't mean the seal's not leaking, though. I'd expect more than one to leak, the way this critter is put together.
Old 07-15-2019, 07:36 AM   #4
widogmom's Avatar
Figured it out.
Thanks again, ddhansen. It was a leak in the seal, and the water is coming from the water heater above, which has a leaky plug. That's why it was that particular bin and no other. Sometimes you have to think horses and not zebras when you have water in your bin LOL!
bin, condensation, l.p., sunseeker, tank
