Originally Posted by Rich5117
Read Johnbryanpeters post made me think of another issue. Is the insulation around the water heater intact. Even a large crack may be letting heat escape. I can reach in and put my hand on our water heater when it is in use the only warm area is the hot water hose coming out the back of the unit.
All your information is spot on for condensation, l am a little embarrassed but l have been dealing with condensation in the cabinets in the bedroom also above the couch and dining table, and behind the headboard of the bed. I have taken care of all these areas. When l started getting water under the kitchen sink, just above the water heater with the cold weather the first thing l thought is condensation, l had replaced sink drains late summer, and did leak checks randomly, no leaks, after l first seen water l re checked the sink, ran water and also let water stand in both sinks, no leaks, must be condensation, wrong, l filled the sink with just hot water to check it once more, l let it set aprox. 30 minutes, a small leak on sink drain presents itself. Have washed dishes since late summer have not seen the leak and only have seen water two or three times. I used plumbers putty and must of let the drain spin a little when l was tightening it. So thanks for all the help all of y'alls advice was spot on for condensation, lol.
