Old 02-01-2016, 11:19 AM   #1
Control Display for 4pt leveling
I've lost the display to my automatic leveling control panel. The battery had been drained while sitting at the dealer's for repair. I was able to raise and lower the front jacks after hooking to the truck's power. The control panel lit up but there was no display on the screen at the time. I thought it may come back after the battery was fully charged but it hasn't. Any ideas?
Steve and Kim
Southern Illinois
2015 Sanibel Traveler 33RS
2011 F350 SRW Crew Cab
si camper is offline   Reply With Quote
Old 02-04-2016, 09:22 PM   #2
CWSWine's Avatar
Mine will not work unless it has a charged battery and won't work just plug into the truck without a full charge on the battery.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-04-2016, 09:35 PM   #3
mlatter's Avatar
I had that happen to mine when I was having battery issues. I pulled the plug off the back of the display to reset it, and when I plugged it back in, all was good.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 02-05-2016, 09:01 AM   #4
Thanks for the advise. Went out and tried that but it didn't work.
I've talked to a rep from PrimeTime. I told him that I've got power to the unit and can raise and lower the legs but there's nothing but a light in the display screen. Was advised that it's probably a failure with the display screen and it needs to be replaced.
I still wonder if the low voltage of a drained battery caused the failure.
Steve and Kim
Southern Illinois
Old 02-05-2016, 09:22 AM   #5
TURBS's Avatar
Is your control box mounted on the door?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-05-2016, 04:35 PM   #6
2015 Columbus 320RS
2008 2500HD Duramax
Its inside the basement storage, attached to the top of the storage area. Not real handy actually and someday I might look at moving it.
Steve and Kim
Southern Illinois
leveling
