Originally Posted by Keith3679
Is it normal for my converter to pull 15 Amps while charging two low batteries?
It's very normal, especially if the batteries are low. Remember that your converter is not only charging the batteries but it's also providing power to all your other 12 v needs. While that load can vary, nevertheless it has to be added to the overall load on the converter's power source.
This is why so many will complain that their generators can't run their A/C or microwave. They forget that when the generator is started it often has to start charging the batteries and that combined with the starting current of the A/C creates an overload.
Best approach is to avoid running the A/C until the batteries have been charged for a while and the initial charging current has dropped off somewhat.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
