05-19-2009, 01:34 PM
Cost to install metal valve stems
I've been thinking about installing a Tire Pressure Monitor System. Most require metal valve stems. I just called Tires Plus and was quoted $25 labor per tire and $10 each for valve stems. That's $150 total. Doesn't that seem just a big outrageous? What are your experiences?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
05-19-2009, 01:52 PM
I would suggest trying other places. I mostly deal with Discount Tire corp. but I don't know if you have access to one in your area. That does sound a bit high. By the way, I just installed a Truck System Technologies tire monitor, just 4 sensors, to keep an eye on the TT tires, and so far I really like it.
2007 Forest River Cherokee 30F
* 14K Equal-i-zer hitch
* TST tire pressure monitor
2003 Chevy Silverado 2500HD Duramax
* 4" MBRP exhaust
* AFE stage2 air intake kit
* Hypertech III, set on stage1
* back-up camera
* Putnam XDR class V hitch receiver
* Airlift air bags
2004 EZGO custom electric golf cart
05-19-2009, 02:20 PM
My tire guy charges $10.00 to dismount and mount a tire and $3.00 each for high pressure valve stems. That is rather you are buying tires from him or not.
This is probably the lowest price you will find.
John U
2007 Rockwood 8315SS Sold 11/19
2014 Silverado 2500HD 6.0L Sold 11/19
Back on the road 10/20
2010 Born Free 22RSK
05-19-2009, 02:21 PM
Metal valve stems run about a $1.50 each. Labor shouldn't be more than $10 a tire. FWIW breaking the bead on a tire isn't that hard. You could probably do it yourself.
05-19-2009, 05:21 PM
Thanks guys. That seemed like a crazy price to me. Thanks for the info on the Truck Systems Technologies. That is the system that I have been thinking that I would buy.
05-20-2009, 08:34 AM
acadainbob, it is time to shop around. My tire dealer charges $9 total for the metal valve stem, installation, and balancing the tire.
05-20-2009, 10:15 AM
Cyber Phrenologist
My 2007 F150 XLT has a factory tire pressure system. Wasn't too sure it worked until it activated one morning on the way to work. Turns out I had those rotten Dill Chinese valve stems! But I got the one that was leaking fixed and that kept me from being stranded on the expressway in downtown Atlanta during morning rush.
Does your F-150 not have the factory system?
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
05-20-2009, 12:10 PM
Naw, my 2006 doesn't have a TPMS. I just looked at both a 2006 and a 2007 F150 brochure that I have, and it wasn't even an option in 2006, but was standard equipment in 2007.
I still only have sensors for my trailer, and not the truck. At $50 a pop ea., I am counting on being able to feel a low tire pressure, where on the trailer you can't feel when a tire is going down. Plus, I monitor the pressure regularly with a tire gauge on the truck, but do rely on the TPMS to check pressures on the trailer.
05-20-2009, 01:42 PM
CampeRooo
I hate to say it, but Walmart might be an inexpensive solution for you...
http://www.walmart.com/catalog/catalog.gsp?cat=495845
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
05-21-2009, 01:47 PM
2005 F150 no monitoring system. Was mostly thinking about the trailer. Thanks for the Walmart idea; never thought of that. It seems clear that Tires Plus is about 2 to 3 times what the cost SHOULD BE!
05-21-2009, 02:01 PM
CampeRooo
No Problem.
When i bought my new rims and tires for my Roo, that was the least expensive place in town to get them mounted. I bought my own heavy duty valve stems from firestone and took them in to their tire center and in 15 minutes, i was loading my tires back into the truck and was ready to go. I can't remember exactly what the price was i paid, but it included the mount, a one time balancing and since i had aluminum wheels, they mounted the weights on the inside of the wheel instead of pounding them onto the edge of the rim. They did a good job and it was well worth the time and effort. I was skeptical at first (scratchs and what not) but they did take good care not to tear them up while they had them.
Where we've been:
