Old 09-30-2019, 02:47 PM   #1
Costar Carbon Monoxide Alarm
Afternoon Friends,
I have a problem with my Costar Carbon Monoxide Alarm Model 9V RV. I have replaced the batteries with fresh alkaline batteries and it still goes off.
I can't find these things anywhere. I think the company is out o business.
Does anyone know of an adequate replacement that i may use that does not require making new holes in the "soft-touch" ceiling?
Many thank in advance!
scusset1 is offline   Reply With Quote
Old 09-30-2019, 06:48 PM   #2
Originally Posted by scusset1 View Post
Afternoon Friends,
Here's a popular brand that is "RV Approved".
https://www.amazon.com/First-Alert-C...IKX0DER&sr=1-2
Most of these units use a hole pattern designed to match a standard wall outlet box so it's doubtful any added holes will be necessary. Some even have a "clover leaf" hole pattern on their back that allows for several different screw placements. I've found it easy to just use the existing screws although I have from time to time had to adjust the screw depth in the ceiling to make the detector fit snugly and not fall off on a rough road.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-01-2019, 09:15 PM   #3
larry2c's Avatar
Just curious, does it mater if a CO detector is "RV rated"?
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
