Old 11-23-2014, 09:11 AM   #1
Farm Living
Cottage/Destination Set-up
Would like to invite Forum participants to weigh in on the challenges and issues associated with more permanent destination trailer set-ups. Yes, it is still an "RV" - just often "parked".
As previously noted, we have placed our Cedar Creek Cottage beside an old cabin we are planning to restore. A lot of this has been "learn by doing" since we had not previously been a part of the RV community. So we thought we'd list a few of the topics/issues we've had to address here so that others might weigh in with their experience and advice. Each of these could probably be their own "thread", but just starting a list should evolve into more specific topics.
1. Wind Anchoring. Wow, was this a good idea. Engaged a local mobile home guy to help us. Using hydraulic jacks and mobile home trailer mover, we removed the wheel carriage, placed the Cottage on blocks, used 3-foot screw-type anchors, cross tied to the I-beams of the main frame. We have experienced 75 mph winds to date with little movement of the Cottage other than a small shiver in a very big gust. The wheel carriage removal was easy, especially since electric brakes just involve a wire.
2. Freeze protected water lines. Yep. Can't have that water hose connected to the side of the Cottage when it is 15F outside (as was last week). The first order of business was to fill the tank and disconnect the hose. But that won't work long term. So we decided to connect the Cottage to the water supply for the cabin. THIS is an interesting project, with the "final answer" still to be determined. We trenched over to the Cottage with hot and cold water lines. We are going to connect the frost-protected supply to the drain-down locations. This required us to:
a. By-pass the electric water heater - simple with in-line by-pass valves that were already in place.
b. ADD shut off valves between the fresh water supply line and the Cottage water filter (to keep he new "supply" from blowing back out of the side of the unit at the fresh water inlet.)
c. Build an insulated column from below grade up to the drain-down outlet locations to keep the supply from freezing.
So, this setup means not using the cottage pump, filter or water heater. We are, instead, using the cabin pressure pump (set at 30/50 psi) and an on-demand water heater in the cabin basement. In checking with several plumbing folk we are confident (so far) that the Cottage water pump will not allow reverse flow and that we will not be filling the fresh water holding tank.
If this works as planned we will:
d. drain the fresh water holding tank and winterize.
e. drain the electric water heater (f) or keep on some low setting? (Advice?)
3. Sleeper sofa issues. Okay. Where can we get a REAL sleeper sofa for the new air mattress we bought? This fold-out thing will not stay together! The snap-in clips on the metal "arms" just will not hold each time we open and close the sleeper. Is there an easy repair to this sofa? Or do we have to spend more money?
4. Rodent proofing. Wow. Field mice LOVE our cottage. As we inventory penetrations we find TOO MANY PLACES THEY CAN GET IN! Electrical penetrations IN THE ISLAND! Beneath the sink... Tiny gaps at every slide. HELP! Also, when I tried to further "weatherproof" the slide gasketing by adding some more foam rope, it seems to just make the gaps to the outside bigger... HELP?
Thanks in advance for your advice and suggestions.
Attached is a recent fall photo from the front door.
Chris-and-Julie
Keywords: Cedar Creek, Cottage, destination, permanent, winterize, rodents, mice
Chris-and-Julie is offline   Reply With Quote
Old 12-11-2014, 03:58 PM   #2
Zoeneens's Avatar
I have been in my Cottage for 4 months now and it has been quite the learning experience for a beginner RVr. Glad you started this topic!
Zoeneens is offline   Reply With Quote
Old 12-11-2014, 04:17 PM   #3
Zoeneens's Avatar
Learning to maintain and use my cottage during winter months. Here's what I've done so far:
Purchased a 50 pt. dehumidifier for cold weather. amazing how much moisture is in the air!
After the black tank is empty, I pour in a gallon of RV antifreeze immediately for easier open and closing.
gray water tanks remain open.
I use city water during the day, make sure my fresh water tank is full, then disconnect and drain hoses at the end of the day while its still above freezing.
I will be skirting with straw bales.
There's more, when I think of them I'll post.
Old 12-11-2014, 04:18 PM   #4
Zoeneens's Avatar
Beautiful view!
Old 03-14-2015, 08:53 AM   #5
Farm Living
Winterizing here included straw bale skirting too. Really helped. Also, many painful lessons of "Cottage Living". For example: merely having the heat ON during single digit temps is no assurance that water pipes won't freeze. See posts in Plumbing.
BTW, winter views are just as nice...
Old 01-26-2017, 08:03 AM   #6
Big-Foot's Avatar
To further seal your slides, you can purchase 8' lengths of 1" foam water pipe insulation at your local home improvement store or hardware store. Close your slides a few inches and then put these foam pieces between the slide fascia on the inside with a little painter's tape to hold in place, then open the slide. It will compress the foam to about 1/2" thick overall and help seal out drafts and critters.
Another couple of questions if I might.
We are about a month from taking posession of our new (to us) 2014 Cedar Creek Cottage 40CFE.
** I am looking for an online owners manual (if one exists)
** Would like to know how deep the slides come out. From the photos we have it looks like maybe 30".. Could someone measure theirs please?
** I had read somewhere that the tongue of these trailers can be unbolted from the chassis - is this correct?
Thanks folks...
Regards - Randy
Regards - Randy
Rage'n Stryker 4005 Toy Hauler 5er
Big-Foot is offline   Reply With Quote
Old 02-15-2018, 07:31 AM   #7
Farm Living
More parked lessons learned
The straw bales are a HUGE benefit, but after a couple of winters we found that adding some simple "air breaks" really helped. We used some thin plywood as a sort of shield to stop air flow at the top of the bales. Really helped on the dominant north facing exposure where most of our wind and weather comes from.
Our slides are always out. We added braces beneath the slide rails to provide some simple support over time - rather than just rely on the rails for support. We got 6 jack braces from the local hardware store and they are (a) cheap and (b) work great.
The slides are about 30 inches as you noted.
Didn't check the tongue, but I assume it comes off. Let mine on. Probably a mistake from the winter straw bale challenges side. We did take off wheels to tie the unit down against the wind. Sitting on cap blocks.
Had 0F temps this winter. No frozen pipes - left them dripping overnight.
Have not been on in a while. Good luck!
