Couple of electrical questions
Installed TV only works if the power converter is on -- even when I'm plugged into shore power. Even if I have the battery cut-off switch to 'off', the TV only works if the dc to ac inverter is turned on. Everything else seems to work without the dc to ac converter on (when the rig is plugged in). Anyone know why they would have wired it that way?
Also -- should I be shutting off the power inverter when the rig is stored?
