Cracks in 2010 pop-up Top
I sure could use some advice.
I have a 2010 Flagstaff pop-up that I bought in December, and I paid $5000 because I thought it was nice and I did not want to hassle with an older unit. This was a major purchase for me. What a mess I am in now.
Now, a few months later, the roof is covered with hundreds of micro cracks and the foam has delaminated from the fiberglass and the fiberglass is wrinkled at the corners and is sagging leaving dips and waves on the roof top. What a mess.
I went to paint it with some Dicor Fiberglass roof coating and as I was rubbing it down I discovered that the cracks are holding water. So I will let it dry more.
Does anyone think these micro-cracks are able to leak water into the unit?
Does anyone think there is a better solution than Dicor paint? Can the whole thing be covered with a rubber roof?
Does anyone think large cracks will appear?
I wonder if anyone thinks denatured alcohol could replace Dircor Prep?
I am not the original owner, and was told a new top is $2000.
I sure could use some encouragement....
Thanks.
