Old 08-24-2014, 08:26 AM   #1
Damaged my TT
Hooked a post at a gas station. Makes me sick. Any guess on repair costs?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 10 nights camped, + booked
Teamfour is offline   Reply With Quote
Old 08-24-2014, 08:33 AM   #2
OUCH!! That might sting just a bit. Hope that was on your way home and not on your way out.
I feel for you.
rana is offline   Reply With Quote
Old 08-24-2014, 08:45 AM   #3
vinmaker's Avatar
It is hard to tell from the photos. Did the back wall get pulled off the frame and off the side walls? Were the side walls pulled off the frame?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-24-2014, 08:52 AM   #4
It happened going to. Wall is not pulled from frame. No interior damage. In fact I can push the corner almost back to where it belongs.
Lee and Anne
Old 08-24-2014, 08:57 AM   #5
If the back wall is stable.. and nothing that could have been seriously damaged behind the side wall GO HARDCORE! Duct tape that puppy up, go have some fun and worry about it when you get home.
That's just me.
Old 08-24-2014, 09:03 AM   #6
vinmaker's Avatar
If there is no damage or separation of the walls then your in decent shape. It might just be a simple trim job. Many times the damage looks much worse than reality as campers have lots of trim and cover pieces that are easily replaced.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-24-2014, 09:14 AM   #7
Jhochst's Avatar
Dang! What a bummer!
Jhochst is offline   Reply With Quote
Old 08-24-2014, 09:35 AM   #8
If you just pulled the corner trim loose and you can push it back then you probably pulled the screws out. I would take the vinyl trim piece out of the metal corner piece, pull the screws and either angle them down or up to get another grip on the wood or aluminum whichever you have or get longer screws and do the same. The back corner trim on mine came loose on one side. I guess they didn't get a good bite on it when it was built. I had some 2" cabinet screws in my tool box left over from a kitchen remodel. They pulled it in tight and I just recaulked it.
OKI Marine is offline   Reply With Quote
Old 08-27-2014, 06:00 PM   #9
Damaged my TT
My finger is showing where the aluminum frame is located behind the rear wall. What about drilling pilot holes through the fiberglass and using screws to pull the panel back to the aluminum stud?Click image for larger version
ID:	61564Click image for larger version
Lee and Anne
Old 08-29-2014, 01:27 PM   #10
Explorer
not being able to put my hands on it makes it tough to give advice.
I am not big on fiberglass siding having any strength to use screw on, with out some nice size washers(fender washers).
I fixed a corner of an old camper(aluminum siding) by cut a piece of metal, slid it under the side trim and bent it to attach under the camper as well(several inches). I like that liquid nails adhesive to hold every thing together and then a few screws nicely placed. Many times your side trim has a plastic that covers the screw heads so putting a few extra there would never be seen. Paint and forget
If you can find something to push pressure(fence, house, bumper of truck and a board or two) against while the liquid nails dries you might not need many extra screws .
its camping, good luck
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
