Old 06-15-2010, 08:55 PM   #1
Damn tires
I finally got around to getting the trailer ready for a trip when I saw the left rear tire was flat as a pancake. I have pumped it up but I have to get it patched before going anywhere. Probably a screw in it.
Everything else worked fine.
Hokiehall is offline   Reply With Quote
Old 06-15-2010, 09:08 PM   #2
milzat's Avatar
Kim,
Have you even replaced the tires?
milzat is offline   Reply With Quote
Old 06-15-2010, 09:29 PM   #3
Yes. After the blow out two years ago I replaced all 4 tires. There is a screw in one as I have found it. It is just the fact I have to fix a basically new tire.
I had to have picked it up when taking it to the mechanic for the annual state inspection. In April it was normal. In mid May, without moving it, it was at 50 lbs. Today it was flat as a pancake.
Old 06-16-2010, 05:58 PM   #4
Yup
Dang trailer tires!
aintgotnun is offline   Reply With Quote
