Old 10-18-2012, 10:20 PM   #11
ironj's Avatar
I will say that one thing I HATED about the regen process is you have no control over it , and if you interrupt it, it won't hurt anything , but the truck will try and restart the regen every time you go somewhere....mine always seemed to start a regen as I was pulling in the garage!!...if you have a tuner or even just a gauge module like the edge insight , you can see the dpf percentage..and I think even on some you can force a regen....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 10-19-2012, 07:11 AM   #12
Trailer Trash
Originally Posted by ironj View Post
New diesel is a single sequential turbo...variable vane....
And the def has nothing to do with the regen process....that is Regen is to clean the soot out of the dpf...and it does make mileage drop but only for 8-10 min by dumping raw diesel into the exhaust
The real old trucks don't have a dpf or def..6.0 was privy to higher sulfur fuel and no dpf or def....hence better mileage and lots of black puffing
Yup I was amazed at the clean tailpipes on the new Fords. In stock tune my 6.0 emits little to no black smoke. The 7.3 was a puffer!
Good article on DEF here. It's for semis but the technology and discussion applies to pickups also.
http://www.cumminsfiltration.com/pdf...es/MB10033.pdf
joelek is offline   Reply With Quote
Old 10-19-2012, 07:21 AM   #13
Originally Posted by joelek View Post
Hmmm I keep hearing the new pickups with DEF get worse mileage than the older ones that didn't run def. When the new trucks go into regen to burn off the soot in the DPF, they use extra diesel fuel. The regen cycles is what kills fuel mileage. I'm a Ford guy and maybe they figured it out on the brand new 6.7L engines but the 6.4 version supposedly gets poor mpg compared to a non DEF 6.0 engine.
How Dodge and their Cummins diesels pass emmissions without running DPF/DEF is beyone me. Ford and Chevy have to do it. Ya I know, Cummins is better. LOL! Before you know it, Chevy will have CAT engines. Ford got burned by International so no way are they going to change for awhile.
GM doesn't need to change out the duramax. It's a terrific engine. Coupled with the allison tranny, it's the best combo out there. Mine gets much better mileage than the pre-DEF chevy trucks that some of my buddies have. Also the tailpipe is amazingly clean. Even my gas trucks have soot in their pipes - not my duramax truck.
I'll probably buy a 2014 if the styling/interior/features are noticeably improved. Otherwise, I'm happy to keep running this one until the wheels fall off.
crasher is offline   Reply With Quote
Old 10-19-2012, 07:41 AM   #14
Now a "Top Member"
EdJunior's Avatar
And I'll say the same thing about the new Ford. My '08 6.4L got pretty bad mileage. But the new 6.7L I'm able to get between 20 and 23 on the highway (unloaded), and close to 19 on my daily driving. I don't do any typical "city driving", so I can't speak to that. My towing is between 10 and 12. Clean, quiet, and very powerful. It's a thing of beauty.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 10-19-2012, 09:41 AM   #15
Lynkage's Avatar
I would have to agree. My 2012 with 1800 miles on it got 12.9 mpg towing 14,000lbs on I-70 from Denver to Moab and back. I was very happy with that!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 10-19-2012, 10:43 AM   #16
Oklahoma Proud
MillerTime's Avatar
Def systems have heaters, and start-up does not require def- giving it time to warm up. Never heard of it freezing solid but it does get slushy at 32.5% mix if it gets cold enough( it is rated to 11 or 12 deg. F. at that mixture)
Def systems DO get better mpgs then the prior dpf only systems, and guess what more epa changes for 2014 and then again in '17 or '18 and yes boys even cummins is not imune to def, its comming.
Seems that I have removed dpfs on dodges durring frame swaps, and I just read that the 6.7 uses a dpf since 07, but thankfully I hardly ever work on them- talk about cramped under a hood!
Old 10-19-2012, 11:40 AM   #17
ironj's Avatar
ya know, for the first few months i owned my truck i pretty much thought all these people claiming 11-12 mpg towing 12k+ were full of it!!!...
ill be the first to admitt mine gets decent towing mpg, i have never seen more than 11.2 avg hand calculated....
having had to opportunity to travel with 8-10 diff ford owners this past year has been rather enlightening......i have seen with my own two eyes, and handy calculator on my phone, some getting 12+mpg towing well south of 12k lbs...same roads as me, same diesel as me....so im slowly becoming a believer....tho my truck has never seen those types of numbers towing, my last trip to dallas netted 23.4 mpg at 70+mph...not bad for a 8k lb small apartment of a LIFTED truck!...the real trade off versus older diesels is COST...all this epa stuff and ULTRA low sulpher diesel makes it a lot more expensive than back in my pappys days! haha
Old 12-25-2012, 12:39 PM   #18
murry52's Avatar
Owners of dura max diesel be very careful Not to Overheat your motor, these motors are aluminum and will not tolerate much heat that diesels require to operate properly
murry52 is offline   Reply With Quote
Old 12-25-2012, 01:06 PM   #19
Oklahoma Proud
MillerTime's Avatar
What?
Honestly nobody should ever overheat any engine, and on almost every engine either the head or block is aluminum and have been for the past decade. I have worked for gm dealers for years and never once heard of a d-max heat/ meltdown failure- only the '05s would run a little warm at times.
Ps. We have about 30-60, 100 days a year here.
Old 12-25-2012, 01:16 PM   #20
Camper Less Camping
Cajun Po-Boy's Avatar
ANY diesel can get overheated, especially towing heavy under a strain in high temps, get EGT temps 1500 degrees or more for longer than 5 minutes and no matter what brand engine you have...your melting gaskets, stretching studs, etc and your in trouble, no matter hat you drive! Be Careful
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
