Hello everyone, new here. I have a 2019 36' 7" (nose to tail) travel trailer, Forest River Cherokee Alpha Wolf 29QB-L, with one large slide out. I'm noticing that when I level it side to side I can get it level in the middle of the trailer and, for the most part, it shows level all the way to the back. From the middle forward, and I'm judging middle from the 4 wheels area, it seems to go off level. I'm using a 24" level, like this one
https://www.amazon.com/gp/product/B0...WM0RG5UL&psc=1 . I've not only tested this on the floor of the trailer but also on the side of the trailer itself and the level changes walking all the way from the back to the front...it's not drastic, but it's enough to make me wonder if I'm doing something wrong. It does get significantly more out of level in the front once I've extended the large slide out.
I am using leveling blocks under the tires to get side to side level and then I put down the power stabilizers. I don't know what else I can do to make the front more level and to keep my levels consistent front to back in the trailer. Is my trailer bending? Should it be if it is? I'm just wondering if something is wrong with it.
I've seen people in videos use manual stabilizers on their trailer to get it level from the corners. I thought you weren't supposed to use those to level? I couldn't even do it if I wanted to either because I thought about that to compensate the other day, and I put more blocks on one side of my power stabilizer than the other. One thing to note is my power stabilizers in the front and back work together so I cannot actually make one corner higher than another. Unfortunately the power stabilizers auto adjust if one side is higher than the other, so it had zero effect.
Any advice would be welcome...I'm worried my trailer is flexing or bending more than it should and something is wrong. Thanks in advance, I look forward to the feedback!
