Old 03-12-2016, 03:39 PM   #11
Hello Itat,
Ive used the Digital Temp. gauge from CDN tire aka(newfie Custom n Speed) for 3 years now and have found it to be quite reliable for checking bearing and tire temp. I know they are a little more expensive but you get what you pay for,,, my too Sense!
ciszzco is offline   Reply With Quote
Old 03-12-2016, 04:00 PM   #12
Originally Posted by DreiHunde View Post
I've used the one from Harbor Freight for over 2 years now and no issues.
Non-Contact Infrared Thermometer With Laser Targeting
Just bought this one this afternoon. On sale, $25.99. Hope it works for at least 2 yrs.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-12-2016, 04:09 PM   #13
Canadian Member
itat's Avatar
Thanks for all your replies. I decided to go with this one.
Etekcity Lasergrip 800
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 03-13-2016, 07:29 AM   #14
AlR
Verify the accuracy by beaming some boiling water. Generally boils around 100 C
2013 GMC 2500 Duramax
- Ride-Rite airbags
2013 Work n Play 18EC
AlR is offline   Reply With Quote
Old 03-13-2016, 10:57 AM   #15
Too Tall's Avatar
Fluke $100
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-13-2016, 04:32 PM   #16
Canadian Member
itat's Avatar
Originally Posted by Too Tall View Post
Fluke $100
If I needed one for my occupation I would have definitely ordered something much better but for my purpose it could be plus or minus 5 deg. Celsius. I just need to know if any one of my brake hubs is significantly hotter than the others so I want consistency more than fine accuracy. Hopefully the unit I ordered will give me that.
Old 03-13-2016, 06:16 PM   #17
It matters little if it reads a bit high or low. What you're looking for are significant differences between tires and hubs.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 03-13-2016, 06:34 PM   #18
Wobbles's Avatar
Question for those that use these devices:
#1 What temp measurements to care about? Do I need to learn mine and then watch for changes after/later on down the road?
#2 What points on the wheel and tire to measure/point the tool at? Dead center on the rim? Center and/or around the rim and or tire? I am asking for directions on a clock, is any hour more important than another?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 03-13-2016, 08:52 PM   #19
Canadian Member
itat's Avatar
I'm no expert but my thought was to monitor the hub/brake drum and the tires. If the hub/drum gets hot it could be a sign there's a problem with the bearings.
Old 03-14-2016, 01:05 AM   #20
Too Tall's Avatar
Looking at TV and RV. Brakes, bearings, tires. Look for consistency.
USMC 68 -70
