Forest River Forums
Sunline User Photos
Old 08-29-2011, 10:45 AM   #1
Boyd's Avatar
Dimmer switch on fan
I have a 1.2 amp 12 volt fan that is too effective which results in it producing enough noise and wash to push a cargo jet down the runway...I'd like to slow it down with a 12 volt 2 pole dimmer switch. I've found them for $20 but think this is a little excessive. Anyone have a source for one that is somewhat more reasonable?
Thanks...Big Wind Boyd
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 09-03-2011, 12:32 AM   #2
2007 WildCat 32QBBS
A single pole double throw switch and an automotive resistor would do the same thing.
1987 F350 Crew Cab Dually 6.9 turbo diesel
87CrewDually is offline   Reply With Quote
Old 09-04-2011, 03:20 PM   #3
jimh's Avatar
i was thinking of a voltage regulator or some diodes in series. problem with both is going to be the heat. the regulator may need a sink.
the diodes, get 2 amp or above and connect them in series until u get the output voltage u need.
resistors will need to be abt 10 watt and will also generate heat.
read the fdw voltage drop of the diodes from the spec sheet. i usually think of silicone as having a 0.6 volt drop. found some at radio shack that had a little over 1 volt drop. u can keep putting them in series until u get the speed u want. i would think if u drop the voltage 3 volts, it will make a significant difference (just a guess).
i used this idea several years ago to supply 9 volts to a microphone from a 13.8 volt source. didn't like buying the batteries.
if u go the 3 leg voltage regulator, u may try putting a variable resistor (POT) on the ground leg to vary the voltage continuously from 5v to 12v. haven't used this idea. believe it will work...just haven't tested it.
i would use that with the switch mentioned by Boyd above. both ideas will work. there are some large wattage automotive resistors (i'm thinking u would start with 5 ohms and work from there). i'm thinking that when u cut the voltage abt 3 or 4 volts, u will see quiet a difference.
jimh is offline   Reply With Quote
Old 09-05-2011, 08:34 AM   #4
jimh's Avatar
the regulator would be a 5v regulator. unfortunately, the regulator idea will probably wind up costing more than the $20 by the time u buy the heat sink and package them.
diodes have a (near) constant voltage drop regardless of applied voltage.
Old 09-10-2011, 07:41 AM   #5
Boyd's Avatar
Sparky Jim
Jim, I am amazed with your extensive knowalge of electronics, if only I were so enlightened.
Relieved and cheered when I learned of a buddy that would be returning to my area via Elkhart, IN., I asked that he snoop around the RV outlets for a dimmer/rheostat that would handle 1.5 amps. Eureka! Yesterday he said he had located one and is bringing it home. Thanks again, "Sparky."
Old 09-11-2011, 07:40 PM   #6
jimh's Avatar
i believe i missed on the wattage of the resistors. looks like i gave it far too much safety factor. if u found one that will handle 1.5 amps, sounds good to me.
glad u found what u needed.
Close [X]
