Old 10-21-2010, 06:11 PM   #21
yvesm's Avatar
Having a woodworking shop at hope and access to the machine shop at work I can always make something real rugged if the new legs from FR don't work out
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 11-01-2010, 06:30 PM   #22
frankm's Avatar
UPDATE: Well I regret to report that the table (at least ours) is definitely wobbly. As in my prior post the culprit seems to be a poorly designed (or not up to the job) single latch that holds ONE of the three sections of ONE leg together when the table is in the upright position. Maybe a second latch on the other leg may have helped.
In the first picture the table is partially collapsed so the sections can be easily seen. In the second picture the table is in its upright/locked position and the gap can still be seen. Multiply this gap times six (two legs, three sections each) and you can start to see how if these sections are not (very) securely held together the whole assembly will be weak. By the way in the pictures the table is upside down resting on the dinette benches.
Ivesm, have you put your table together yet? What did you find?
ID:	3775   Click image for larger version
frankm is offline   Reply With Quote
Old 09-18-2014, 03:57 PM   #23
Wobbly Table - Solution?
Did anyone find a solution to this? I have the same problem in my 8281WS
jdauter is offline   Reply With Quote
Old 09-18-2014, 04:20 PM   #24
I have 2 posts and the floor and table cups if someone wants to pay shipping, they can have them.
Old 09-18-2014, 05:11 PM   #25
Originally Posted by red dirt View Post
Stevieboy,
I also have a 2010 Rockwood 2604.
I asked the dealer about putting in pedestal legs, but said that was not a good idea since the pedestal support would have to be screwed into the plywood floor which is part of the slide. If the screws were too long it would ruin the carpeting underneath.
You could probably replace the legs with something similar to the existing legs, that were a bit stronger without any problem.
The other thing I was thinking about was installing the Dream Dinette table, but I don't know how much reinforcement would need to be added to the wall.
http://www.casshudson.com/catalog/display.php?product_id=232
I spoke to my dealer about it, but he was not aware of anyone who'd done that with the 2604.
If you have a U shaped dinette I would remove the cups on the floor and cut a piece of 3/4 inch plywood to fit in the floor space. I would,get the Sequoia Table Leg System and screw the base plates to the plywood (carpet the plywood if desired) so no screws go into the slide out floor. I did something different but you could get the idea.
Name:	ImageUploadedByForest River Forums1411078259.071202.jpg
Name:	ImageUploadedByForest River Forums1411078272.825741.jpg
Just picture that in the U shaped dinette.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-18-2014, 06:13 PM   #26
Timex's Avatar
I'm surprised you could renew the thread since it is 4 years old!
My wobbly folding mechanism bit the dust back in April.
So I replaced with pedestals. No more sloshing drinks!
ID:	63041   Click image for larger version
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 09-19-2014, 06:36 PM   #27
iluvlcy's Avatar
Is that on a slide floor? How did you mount leg bases?
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 09-19-2014, 06:38 PM   #28
dinette table legs
They are mounted to 3/4 inch plywood with 3/4 inch screws. Very sturdy.
And it is in the slide out.
Old 09-19-2014, 07:00 PM   #29
Timex's Avatar
Couldn't have said it better myself!
Drilled a pilot hole for each screw. I used a piece of masking tape around the drill bit at 1/2" so I wouldn't drill through the plywood and mistakenly hit something.
Here is a couple of pics of the plywood under the carpet and the bases on the floor.
ID:	63105   Click image for larger version
Old 09-19-2014, 09:13 PM   #30
iluvlcy's Avatar
So you did not add plywood just drilled into what was there?
Appreciate the responses!
Pam & Don
2011 Rockwood 2304s
