Old 03-20-2012, 05:00 PM   #1
froggy's Avatar
Cool Direct TV Local Channels
Well I hooked up the sat. dish to the receiver to the TV and got 85% on the Signal meter. We can get lots of our regular upper channels 200 and up. We DO NOT get our LOCAL channels or lower 2 thru 13. Help?
This was my first test at home in the 85737 Oro Valley AZ zip code. I get the local channels in the house using the slimline 5 s BUT not on the receiver using the tri-pod 18-inch round dish. Any ideas?
Forest River, Palomino, 2010 Sabre 31 RETS
2010 Dodge Ram 3500 ST Crew Cab 4X4, 6.7 Cummings Turbo Diesel, SRW, Short Bed, Reece 15K Slider Hitch
froggy is offline   Reply With Quote
Old 03-20-2012, 05:08 PM   #2
TURBS's Avatar
Do you have 3 lnb's?
One = normal
Two = local
Three = hd
Old 03-20-2012, 05:18 PM   #3
froggy's Avatar
I have 1 lnb
Old 03-20-2012, 05:19 PM   #4
I'm down here in Tucson and that has happened to us with Direct TV in the 5er. Either call customer service (1-800-531-5000) or hit the reset button where you installed your card in the receiver...It will take a few minutes. We have the standard receivers in the 5er.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 03-20-2012, 05:30 PM   #5
TURBS's Avatar
you need at least 2 for local sorry
Old 03-26-2012, 09:28 PM   #6
mike54's Avatar
Attachment 11058
since when? I only have one on my 18" round and get locals if I'm within 150 miles from home
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 03-28-2012, 07:07 AM   #7
Big Dawg's Avatar
I use the 18" round also, and get my locals here, and when camping.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 03-28-2012, 10:08 AM   #8
Head Rambler
Some localities locals are on a different bird than the normals. Some places need to see 99 and 103 in order to get all the channels.
Gotta go campin!
Old 03-28-2012, 10:14 AM   #9
frankm's Avatar
This is the correct answer. Directv has been "spot beaming" local channels for years so if you are out of your receiver's local area it won't get local channels. Here is Directv explanation:
Why can't my mobile vehicle account have my local channels from my original location?
Due to FCC regulations, the broadcast signal for local channels may not be available in all locations. Your local channels are delivered via a spot beam satellite that targets areas immediately around a city where you live, like a spotlight. Since your mobile receiver displays the time zone from your home service address, your local channels will not be available if you leave the satellite spot beam area.
Example: If your primary receiver is in Tampa, FL, and you are in an RV in Seattle, WA, the RV receiver won't get local channels, because the satellite transmits signal only to the area around Tampa, FL. As soon as you drive your RV inside the Tampa, FL, spot beam area, you will be able receive the Tampa locals again.
DIRECTV Why can't my mobile vehicle account have my local channels from my original location?
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 04-02-2012, 01:37 PM   #10
rracer5's Avatar
But, he said he was "at home" testing the sat. set up.
Froggy - Is your LNB round or slightly oval? How about the one for the house? If it's oval on the house it MAY have 2 "eyes" in the head and picks up more than the main 101 sat. I may be quessing here but, I have seen lots of combinations of LNB heads on the same dimension dishes lately.
Froggy - Just re-read your post and see that you have a Slimline 5 dish on the house. In that case, if you haven't done so already, you have to change the setting in the receiver as follows; MENU, SETTINGS, SATELLITE, and change the satellite type to the 18" round setting. With the 18" round you won't get too many HD channels. You may also have to change the following in the receiver also; MENU, SETTINGS, DISPLAY, PREFERENCES and change the "Guide channels" to SHOW SD DUPLICATES. Otherwise, you will get a lot of "searching for satellite signal" messages because it's looking for HD channels that are not being picked up by the 18"round dish which should be pointed at the 101 satellite.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
