Old 09-14-2010, 06:52 PM   #1
Directv set up in motorhome.
I just got Directv service at home and was given an Rv kit. The kit has a tripod, dish,cable and a window cable hook up. I know how to set up the dish and tripod but am lost from there. Where do I hook up the reciver and cables in the motorcoach and the dish. Thanks
texasgeorge is offline   Reply With Quote
Old 09-14-2010, 07:19 PM   #2
Hatchet58's Avatar
Dont ask me, I still have VHS
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline   Reply With Quote
Old 09-14-2010, 07:19 PM   #3
piscesman's Avatar
It's pretty much the same as a home setup....you need to locate your receiver close to your TV where you can access AC power. I put mine in the upper cabinet on the rider's side next to the TV. Unless your motorhome is wired for satellite (satellite ready), you cannot use the "cable" system (CATV) that often has an external co-ax box on the side or in one of the hatches. The satellite cable goes from the LNB on the dish, through a window (via the flat ribbon adapter) and into your receiver. You connect the receiver to your TV via a co-ax cable, component cables (3) or an HDMI cable. I installed a short length of cable from the cabinet to the floor and hid it behind a piece of window trim to make it easier to connect my cable from the dish each time I set it up. Of course, now you have to aim the dish which is another story.....
2003 GEORGETOWN 325
"NOT ALL WHO WANDER ARE LOST"
Nights camped in 2011: 108
Nights camped in 2012: 41
piscesman is offline   Reply With Quote
