Old 05-30-2009, 07:00 AM   #1
Chris and Sara
dirt and debris in ducts
I have noticed alot of dirt and debris in my floor ducts. I found some filters at Wal Mart that you can put underneath them to stop the debris. Do you guys think that this will hurt my furnace at all, I.E. restrict the airflow too much? They are just made out of some filter material, they are designed for residential ducts.
2004 F-150 with Tow Package
2009 Flagstaff 829 FKSS
Prodigy Brake Controller
Equalizer Hitch
renegaderailfan is offline   Reply With Quote
Old 05-30-2009, 07:40 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
You run the risk of creating too much back pressure and having your furnace kick off by over heating through the limit switch. Besides if that material would come loose it could blow down into the duct and wedge where getting it out may present a big problem. Personally I wouldn't do it, the time it takes to remove the registers and vacuum out the dirt isn't that bad as opposed to creating a bigger problem when the furnace overheats and shuts down. I've been in the HVAC Business for over 33 years.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-30-2009, 08:41 AM   #3
Chris and Sara
That's what I thought, thanks. Also what is your opinion on the screens on the outside furnace vents? I have read several opinions on these restricting exhaust flow, and damaging the furnace.
Equalizer Hitch
Old 05-30-2009, 09:42 AM   #4
Those screen shouldnt restrict air flow but they do keep thing from building nest in there which can cause a fire
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 05-30-2009, 02:06 PM   #5
donjuanss's Avatar
When I had floor vents I used regular window screen material. Just cut it to the size of the vent not the hole then set it down and put the vent back on it. It really helped keeping big things out of the vent.
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 05-30-2009, 02:17 PM   #6
NWJeeper's Avatar
That's a good idea. The gas furnaces on RVs requires a certain amount of air movement or the burn chamber can overheat. I don't think that the filters would initally be a problem in most cases but you would have to be very carefull to change them out regularly. I like the window screen idea though, might just have to do that myself.
I would think though that if you were to put a metal cover with say a 1" dia. hole over the vent at one end of the run, then complely cover the other vents along the line, then put a shop vac at the other end of the run you could suck just about anything out of the vent system to clean it out once a year.
Ed & Wendy
www.nwjeepn.com
