Old 08-09-2011, 10:39 AM   #11
Steve09's Avatar
Thanks alot for all the imput,,,didn't mean to start a fuss,,,lol,,,thanks
2009 Salem La 292FKDS--7600 lbs
2006 F250 fx4 Ext Cab,Diesel
(sold)2004 F-150 5.4 Auto FX4 3.73 Gears with Factory Tow Pkg, 36 Gal Tank, 96,000 miles ,Equalizer Hitch 10000 lb Bars ,MBRP 3in Cat-Back Exhaust SI/SO
24 Days in 09, 35 Days in 10, 24 Days in 11,,23 Days camped so far in 12, 22 Days Camped in 13,,6 Days Camped in 14
Steve09 is offline   Reply With Quote
Old 08-09-2011, 10:40 AM   #12
I just followed the instructions that came with the marine battery disconnect switch that I recently purchased. Said to install it on the positive terminal wire. Which, being an electronics tech in my previous life - I would have done anyway. BUT it will function just as well on the neg (ground) side.
....VTX-AL
VTX Al is offline   Reply With Quote
Old 08-09-2011, 01:08 PM   #13
Steve09's Avatar
ok,,thanks alot,,I was just afraid of sparks .
Old 08-09-2011, 01:14 PM   #14
No fuss, we are gently discussing it In a very civilized manner too, which pleases me a lot.
Go ahead and install it on the positive side, well negative if you really want to. Just have one though. Nothing is worse then going to your trailer and finding out that the battery is dead. Especially if you really like your power tongue jack like I do ...no, please do not ask me how I know it sucks to have a dead battery
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 08-09-2011, 01:23 PM   #15
KyDan's Avatar
If you cut either battery wire you will shut off the battery system.
No argument there.
Our RVs are pretty much all negative ground.
That simply means pretty much everything in the RV has one lead going
to frame/ground/negative on the battery.
Fuses, switches, 12v circuit breakers that turn things on and off go in the
"hot" lead which in most RVs is gonna be the PLUS side.
(Hot being a wire that will read voltage between itself and ground.)
In my trailer that includes the battery disconnect switch.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-09-2011, 02:22 PM   #16
I've always installed the shutoff as close as possible on the Positive terminal. Usually it was attached to the terminal. Never thought of using the negative side, while it would certainly work that just seems strange and foreign to me. Must be my electrical engineering background...
If I was physically removing the battery I'd do negative then positive to avoid shorting anything with tools. But if it was an attached switch mechanism I just use the hot side.
2005 Ford Excursion V10 4x4 4.30's
2011 Salem 26TBUD
brianb is offline   Reply With Quote
Old 08-09-2011, 02:49 PM   #17
Regarding switch contact arcing when making or breaking the circuit. If there's a load, the switch contacts will still arc regardless of whether you're switching the positive or negative leads. The current potential does not go away.
If you want to test, turn the lights on in your TT and disconnect the negative lead (preferably not at the battery) and touch it a couple of times to make the circuit. You will still have arcing. No way around that.
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
dlhoppe is offline   Reply With Quote
Old 08-09-2011, 02:57 PM   #18
Think of it this way. If you switch the negative, all the circuitry in the TT becomes 12v+ (all the way around to the TT side of the disconnect switch). Is that a problem? Not sure, but I'd rather not do it that way.
Equalizer Hitch
Old 08-09-2011, 03:37 PM   #19
jimh's Avatar
way back in the old days of points in an automobile....they put a condenser (capacitor) across the contacts. that would cushion the interruption. still will get some spark but very little. i'd say try a 0.5uf and see what happens.
jimh is offline   Reply With Quote
Old 08-09-2011, 04:30 PM   #20
On my tt. I initially tried the switch on the ground wire, had 2 batteries in parallel , but was never able to make the switching work off , so did the positive. My guess is that there must be a frame ground completing the circuit somewhere.
jleon01 is offline   Reply With Quote
