Old 07-25-2012, 12:02 PM   #1
3 Happy Campers's Avatar
Dish TV
My newest toy arrived this morning!
I was going to wait until Saturday to set it up & activate it but as soon as the delivery truck pulled in the driveway I knew I wouldnít be able to wait!
Set up on the America's Top 120 month to month plan @ $44/mon.
Name:	DISH Tailgater.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 07-25-2012, 12:18 PM   #2
Oakman's Avatar
We really like our Tailgater. We went with the basic package for $34.99 but the price includes HD and local channels. When we were in Colorado we were able to keep up with where the wildfires were burning throughout the state through the local channels. That was a big plus. Dish was smart marketing the Tailgater to RV’ers, I‘ve been seeing more and more of them at campgrounds.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-25-2012, 12:23 PM   #3
jimh's Avatar
i have one. the price was right and it is the easiest thing that i ever set up.
the local channels may not be available to u (work) if u travel out of ur area. i've noticed when we go to tn, we get an out of area msg.
one thing i would add, you can buy an external hard drive, pay dish a one time fee of abt $40, and u have DVR. it behaves just like the DVR's ie speed and controls.
jimh is offline   Reply With Quote
Old 07-25-2012, 12:41 PM   #4
Yeah was a little bummed that we wonít have our local channels in a couple weeks while @ FROG. Wasnít about to pay another $12 for the national ABC, CBS, NBC package.
Iím actually dusting off an old SATA hard Drive enclosure & a 500G hard drive Iíve had sitting in the closet.
Off the top only problem is I can only sync to one satellite while sitting in my driveway. Too many trees.
One of the stations I canít pull in from the driveway is HRTV. DW was bouncing off the walls when she found out weíd be getting that ch.
Perkasie, PA
2010 Sierra 356RL
Old 07-25-2012, 12:59 PM   #5
Oakman's Avatar
You can get the local channels of the area you are going to which usually includes the major networks. Just call DISH, you will need the address of the campground not just the zip code, and tell them you want the local channels for that area. You will have to change it back when you return.
Bob and Joyce
ATU Local 788
Old 07-25-2012, 01:28 PM   #6
jimh's Avatar
i'm using a WD something book 1 T. there was one other that had been tested and known to work. u call dish and they send down the code to format it and make it work with the receiver. the question i would ask is if u can change drives w/o calling them. you would want to know if the receiver would format a new drive in case the one ur trying doesn't work.
i have 350 hrs of sd left now and have quiet a bit on it.
one of ur options is to unmount the drive. i'm afraid to try it w/o asking dish if i can remount it w/o calling them.
Old 07-25-2012, 02:23 PM   #7
Swapping HDs, good question!
I was kinda hoping I could bring the HD in the house & watch the shows on my TV via my PC.
Wonder what format it records in? Probably some proprietary format.
While camping I donít expect to be using the DVR too much.
I donít care much for watching TV while camping as it is.
The only reason Iím adding the drive is itís another gadget & he who dies with the most toys wins!
Perkasie, PA
2010 Sierra 356RL
Old 07-25-2012, 05:57 PM   #8
jimh's Avatar
i know u can power up with the drive disconnected apparently w/o consequence.
the format, i don't know. sense all is working, i'm leaving it alone.
i would ask dish but don't believe their reps would know. when i had it set up the first time, i followed directions then called dish. the rep wanted to send someone out. he asked someone else then the code was sent. i would like to see some written info on it other than the set up.
one thing that i ran into on my 2002 was that i would miss channels. 205 comes to mind. i would get the reset page and have to wait before i could change to another channel. what i found was a splitter that was more for reg tv instead of sat (it did have the dc pass though). that probably wasn't a problem in 2002 but they raised the band width sense then. that probably won't be a factor on the newer trailers.
i'd like to know how u come out with the drive. other than a separate power source, i don't know what else the drive had to do.
