Originally Posted by skeeterbait8
That sure would be great if it could be done from the inside. It's not fun to be an older and larger person to crawl all over stuff.
i'm nearly 56 years old and weigh around 230lbs.
and i'm fine about being on the roof. i do put a sheet of plywood if i have to go towards the center of the roof.
i'm confused about your issue. what you are calling the "switch", do you mean the crank that raises the cover? or the round switch that turns the fan on?
the only switches in the 23SS bathroom are the switch on the wall, next to the toilet, the round fan switch and then the light switch over the sink.
the vent cover has a crank and arm assembly that raises and closes the cover. never seen one with an electric switch to raise and lower it. at least one that comes on a 23SS.
