Old 06-20-2016, 09:15 PM   #1
Jeanny's Avatar
Dometic A/C help please.
Not sure if this has been covered in previous post but maybe someone has had the same problem and could offer some help.
A/C cooling fine but when it reaches the desired temperature and shuts down, it immediately kicks back on and trips the breaker. Any Ideas and comments greatly appreciated! And please hurry!! Forecast 100 degrees coming up😓LOL
Jeanny is offline   Reply With Quote
Old 06-20-2016, 09:44 PM   #2
Bluepill's Avatar
Year, Make, Model?
There is supposed to be a delay circuit to keep that from happening. Sometimes in the thermostat, sometimes in the A/C unit itself.
A quick possible fix is to remove the thermostat, unplug the wiring for 5 minutes, then re-plug and refit the thermostat. This will reboot the microcontroller in the thermostat.
Like all computers, they get wonky from time-to-time.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 06-20-2016, 10:18 PM   #3
Jeanny's Avatar
Thank you Bluepill! The year is 2005...Duo'Therm by Dometic....
Old 06-20-2016, 10:20 PM   #4
Jeanny's Avatar
Still trying to find model number
Old 06-20-2016, 10:29 PM   #5
Bluepill's Avatar
Usually a decent internet search will lead you to factory owner and service manuals. Location of the delay circuit should be there.
A temporary work-around is to set the thermostat to absolute minimum. When the temp. gets a few degrees lower than you would like it, turn the unit off. When the temp. rises to the point where you want A/C again, turn it on.
Old 06-21-2016, 08:27 AM   #6
If you take off the return grill and look inside the AC unit you should find the model #.
Old 06-21-2016, 05:48 PM   #7
Will rebooting thermostat work in 2002 Salem TT ?
Louisiana Irishman is offline   Reply With Quote
dometic
