Originally Posted by snoopyf150
The Dometic Awning Strip Lights on my 2017 FR Sierra Destination trailer,39RL, .stopped working. I checked the fuse block inside the main control panel( on wall just inside my sliding glass doors) where breakers are located and all are ok. Breakers are all “on”. Is there a second fuse panel somewhere I am missing? I checked light wires at the awning. No issues or damage. If I have to replace the strip is there a procedure for removing it? Any help, suggestions to troubleshoot would be greatly appreciated. Thanks
When you say you checked "light wires at the awning" do you mean that you checked to see if you had power there and you did?
If so, that surprises me as LED's generally last a long time. Must have got a bad set. If all the fuses are good, that would have been the first place I sent you looking, for a pinched, broken wire as that or a corroded or bad connector are usually the reason for LED's going out.
As far as the procedure for removing the light strip, it depends on where and how it's mounted. Some are just held on by self adhesive. Some are mounted under the edge of a rail and some are screwed in place every so far. So your going to have to identify which of the above you have and report back for a solid answer.
