Old 04-05-2016, 03:35 AM   #1
Door lock pulled out with key
Just brought home our new 323 mk Wildcat. Went to unlock the door of the handle lock. Key didn't turn easily but did turn. When I went to pull it out the key tumbler pulled out as well! Now what do I do?
rogerkathy is offline   Reply With Quote
Old 04-05-2016, 04:21 AM   #2
nomad297's Avatar
It sounds like you were given an extraction key which is designed to do just that, but I doubt it. Your dealer, or you can get a new lock easily.
Bruce
nomad297 is online now   Reply With Quote
Old 04-05-2016, 08:40 AM   #3
Head Rambler
Since it's new I'd have the dealer replace the lock.
Gotta go campin!
Old 04-05-2016, 10:06 AM   #4
The keys don't seem to be going into any of the locks easily. Wondering if it's a good idea to use a little WD40 on all the locks or is something else recommended?
Old 04-05-2016, 10:40 AM   #5
SeaDog's Avatar
If the lock cylinder pulled out that means more then likely the clip on the rear of the cylinder came off. You will have to remove the inner door panel to get at the lock and replace the clip. Keys inserting hard may be to them not haven been buffed enough and the sharp edges of the keys I would not think lub is the problem.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-05-2016, 10:46 AM   #6
rsdata's Avatar
lube if you want with a graphite spray made for locks, NOT WD-40 available at locksmiths or hardware stores
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-05-2016, 12:06 PM   #7
MilCop4523's Avatar
is your key Blue in color?
the extraction key is what happened either that or the factory didn't set it correctly
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 04-05-2016, 01:42 PM   #8
Liquid Graphite
The best way I've found to lubricate locks is to use a liquid graphite called Lock Ease. I had a 2009 lock do the same thing. Good time to change locks and get one that everyone else can't open with their key.
mnoland30 is offline   Reply With Quote
Old 04-05-2016, 02:48 PM   #9
Also look /search/ for a thread a few weeks ago about bad locks. This was a problem with one batch of locks.
AFDON is offline   Reply With Quote
Old 04-05-2016, 03:38 PM   #10
DustyRoads's Avatar
My lock on my 2014 trailer did the same thing. I ordered a new assembly from the below site. I had it keyed to match original and other locks. This being very new I would ask the dealer. Mine was just out of the bumper to bumper warrantee.
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
door, led
