Old 03-01-2011, 07:43 AM   #1
Drain holes on 2004 Rockwood
I have two drain holes on the back right side of my trailer and everytime I put water to my trailer one leaks..Question is what are they for and how do I stop it from leaking...Thanks
chaoscm is offline   Reply With Quote
Old 03-01-2011, 08:07 AM   #2
Those would be your low point drains that you use when you winterize the trailer. As for the leak turn off water supply & if there are caps on the lines see if you can tighten the caps. If they are valves that turn to open & close try opening & closing them a few times. If this doesn't work they may need to be replaced.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
