Old 07-22-2015, 01:31 PM   #1
Drilling into A-frame
I picked up my 2016 2306 at the weekend and I want to fit a friction sway bar to the A-frame. This means drilling 4 holes for the self-tapping bolts - will the warranty be ok? Anything else I need to know before ?
Simonpk is offline   Reply With Quote
Old 07-22-2015, 01:44 PM   #2
This Hole Drilling is performed often,but I have Never seen a Written OK from the (Frame MFGs.) Youroo!!
Old 07-22-2015, 01:53 PM   #3
Pixelbum1's Avatar
Drilling the frame?
If it's a tubular-type frame as on the Solera I would be a little nervous as that
"could" be a point for a future tear or fracture, esp. if done near the middle or a high-stress area...dunno? They did not design it to have little chunks of this
frame missing or drilled out? Making sure the frame is an iron alloy(test with a magnet) vs. aluminum(???) I would be prone to welding vs. drilling. If done
right it could add to the strength and not possibly take away? Just
speculating here FWIW...be safe and check!
PS: maybe it's ok as long as you don't go over the "holes drilled #" quota?? ;]
Pixelbum1 is offline   Reply With Quote
Old 07-28-2015, 09:19 PM   #4
I wouldn't worry about it. That's how the dealer mounted mine.
wickedwyrm is offline   Reply With Quote
a-frame, frame
