Old 05-31-2010, 06:07 PM   #1
Dripping, normal or an issue?
While camping this weekend I noticed a drip comming from the under the camper. After further investigation I found 2 drain tubes hanging through the floor. One was blue and one was red. It seemed to be under the shower. The hot water tank is no where near this. any ideas? We're planning a trip to Washington DC and don't need any problems.
dano 2 is offline   Reply With Quote
Old 05-31-2010, 06:32 PM   #2
NWJeeper's Avatar
Just a guess but sounds like low point and fresh water tank drains. They shouldn't be dripping.
Ed & Wendy
www.nwjeepn.com
Old 05-31-2010, 06:36 PM   #3
These are the low point drains for your water system. They should either have screw in plugs or valves. If the dripping is from these, then tighten the plugs or close the valves. The only reason to use these is to drain the water system for winterizing or maintenance on the system.
Ray
'04 Dodge 3500
'11 Flagstaff 8528RLWS, Hijacker 16k slider
HTR member Nights camped 2010 -115, 2011 -40 , 2012 -41, 2013 -86,
seatosea is offline   Reply With Quote
