Old 01-10-2015, 07:42 PM   #1
Roger and Paula
E-450 dash air fix
My Coachmen MH is on a Ford E-450 chassis. Dash air went out, only blows through the defrost vent. Ugh.
So after a lot of research I found that Ford, in its infinite wisdom, runs the vacuum line that runs the system through the AC system...where you cannot get to it. Coat to repair at the dealership is BOING because they disassemble the whole system to replace one vacuum line.
So here is the fix
Remove the engine cowl inside the cab. There is a RED vacuum line that runs up to the front of the engine compartments, transitions to black (you can test for vacuum there-should have vacuum with the motor running). Line runs through the AC and out just above the floor on the passenger side (check for vacuum there-won't be any). Disconnect the red line, run it through the dash area (will probably have to drill a small hole and seal it, connect to the black line on the passenger side. A half-day chasing vacuum lines, etc and you have it does e for a few bucks.
Hope this helps someone.
Rstrahan is offline   Reply With Quote
Old 01-11-2015, 06:25 AM   #2
Good information.
Thanks for posting your problem and fix.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
RamblerGuy is online now   Reply With Quote
Old 01-16-2015, 11:27 AM   #3
Spikedog's Avatar
What year is your rig? Gas or Diesel?
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 01-16-2015, 06:08 PM   #4
Roger and Paula
2002 gas. This issue affects the gas models due to the way the vacuum line is run through the AC instead of directly to the vacuum controls. So there are numerous years that this affects.
