Old 04-06-2012, 02:35 AM   #1
bush's Avatar
E1 code. install new thermostat
i have the E1 error code again and tried to reset it like i did here
http://www.forestriverforums.com/for...-e1-14668.html
but it didt work. so i was going to install a new thermostat a honeywell RTH111B. so i went to take the factory one out and only 3 wires are connected. red,green,white.
there are 4 wires that are not used. yellow,blue,brown, and a bare wire.
so i went to the A/C unit to find where all the wires go and they are all cut but the 3 used on the factory thermostat.
so where do i go from here???
2011 puma unleashed 298fqu toyhauler.
hauling a 2012 polaris RZRS
pulled by a 2006 chevy 3500 drw 4x4 duramax lbz
bush is offline   Reply With Quote
Old 04-06-2012, 06:23 AM   #2
Herk7769's Avatar
Got this from a manual on Carrier Thermostats:
Table 4 Thermostat Error Code Descriptions
ERROR CODE DESCRIPTION
E1
The system is not communicating properly. Call the local Carrier representative for service
E3
The temperature sensor has failed. Call the local Carrier representative for service
E4
There is an internal memory failure. Call the local Carrier representative for service
E5
The humidity sensor is not working. Call the local Carrier representative for service
I am thinking the wires are not hooked up right.
Another solution...
HAM CALLSIGN - KC3FFW
