Old 12-15-2019, 09:32 AM   #1
Electric fireplace beep
I have a 2020 rockwood 2511sb with ele fireplace. When the furnace comes on the fireplace beeps.makes it tough to sleep.
jdgooch8479 is offline   Reply With Quote
Old 12-15-2019, 10:31 AM   #2
Kanadian Kamper
kenandterry's Avatar
Electric fireplace works on 120VAC.
Furnace works on 12VDC.
Do you have any paperwork for your fireplace that might indicate what a beep would be for? The furnace should have nothing to do with your fireplace. You sure it’s not the CO alarm or smoke alarm making the beep?
Ken and Terry
kenandterry is offline   Reply With Quote
Old 12-15-2019, 10:34 AM   #3
NMWildcat's Avatar
X2. Never heard a fireplace that beeped. I'm betting it's an alarm sensor beep, a detector low battery indicator beep, or a co expired life beep.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 12-16-2019, 06:20 AM   #4
Just wondering if maybe if the fireplace is set to a temperature, after it goes off, then goes, back on, it beeps. Try just turning on the fireplace to just high and see if it still beeps. Just a thought.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 12-16-2019, 07:19 AM   #5
I'm betting it is a CO or smoke detector that is beeping. The origins of their sound can be elusive. It may be time for a replacement.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 12-16-2019, 09:17 AM   #6
Commercial Member
ES_FR's Avatar
jdgooch8479,
We would be happy to assist you with your fireplace. Please contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...20845332642085.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 12-16-2019, 10:46 AM   #7
NMWildcat's Avatar
Please let us know what FR tells you.
I was just down at the local RV service shop (they have good coffee that attracts us old farts) and they said that yes, some electric fireplaces will beep when any control button on the unit or the remote is pushed. You can turn off the beep on some units with the remote or something like pressing the timer button for 5 seconds.
So look up the online owners manual for your particular fireplace and see what it says. If there is no beep turn off, you can always find the mechanism on your fireplace and disable it.
Happy camping!
Old 12-16-2019, 10:58 AM   #8
Originally Posted by ES_FR View Post
jdgooch8479,
Respectfully,
Forest River
Does anyone ever get any satisfaction from this canned response?
Old 12-16-2019, 11:03 AM   #9
I most definitely have.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 12-16-2019, 12:39 PM   #10
No it's new 2020.i can see the flash of the screen on the fireplace when it beeps. Spent the weekend looking for the issue couldn't find it. I found one small pamphlet about the fireplace.
Old 12-16-2019, 12:45 PM   #11
NMWildcat's Avatar
Yep, that would be aggravating at night! Have you looked at the fireplace manufacturer's website for an operating manual or a number to call?
Old 12-16-2019, 12:51 PM   #12
Each response seems tailored to direct the customer to the correct contact for their unit. I, too, would like to hear how well this worked out for the customers. I'm really glad to see Forest River making this effort.
Andersen hitch
Old 09-21-2021, 10:38 AM   #13
Talking Bust the Dust
Dust will cause the fans to stop or coils to burn and trigger the auto-shut-off.
It is usually this causing the issue.
Solution: Get a really good leaf blower (I love my Rigid jobsite blower) and blow the crap out of it in front and from the air intake behind. Then Swiffer duster it and blow it again. This usually does the trick. Probably good to do once or twice a year.
Dr. Know it all is offline   Reply With Quote
Old 09-22-2021, 08:07 AM   #14
Roaminaround's Avatar
I disassembled my fireplace and found the culprit. Ran a drill bit into it and killed it. Here’s what your looking for. Our unit beeped every time a function was pressed on the unit or remote.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
electric, fireplace
