Old 06-24-2014, 04:50 PM   #31
Facing the manual end, turn the crank clockwise. It is pretty hard to turn as the motor has a gearbox and you are going against the gearbox.
Old 06-24-2014, 04:51 PM   #32
Fulltime family RVer
nothing is visibly vent, but it's all pretty hidden from view with them being retracted.
Name:	ImageUploadedByForest River Forums1403646596.921131.jpg
ID:	56256Click image for larger version
Name:	ImageUploadedByForest River Forums1403646619.295102.jpg
ID:	56257Click image for larger version
Name:	ImageUploadedByForest River Forums1403646674.647526.jpg
Old 06-24-2014, 04:52 PM   #33
Clockwise- ok, opposite to what I thought. But it was tough either way. I'll try again after dinner.
Old 06-24-2014, 04:54 PM   #34
Phat Phrog Stunt Crew
elind's Avatar
If you have a Lippert jack you have a place to put in a hand crank opposite side of the motor. Give it a crank both ways to see if it breaks loose. Something could of bent and jammed up. You might need to get rough to loosen it.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 06-24-2014, 05:07 PM   #35
Herk7769's Avatar
Pop the motor off first.
It will make troubleshooting the screw a lot easier.
HAM CALLSIGN - KC3FFW
Old 06-24-2014, 05:18 PM   #36
rattleNsmoke's Avatar
Agreed. Remove the motor, lube the worm gears with WD-40 and work the legs down.....carefully. I would use a pry bar and give them a gentle shove. I had mine hang up due to extending and weighting the legs on a slope. That small twist locked one of them up. Doug, they have to come down....or off...else you'll be having a very wobbly camping trip come July.
rattleNsmoke is offline   Reply With Quote
Old 06-24-2014, 05:32 PM   #37
Removing it now...
Old 06-24-2014, 05:56 PM   #38
When you get the motor off, you are going to have to have someone pry the legs down while you manually try to lower them. You evidently jammed them in the up position the last time you retracted them.
Old 06-24-2014, 05:57 PM   #39
I'm annoyingly slow, but I was able to disengage the motor. The jacks were still stuck and required some forcing to break loose whatever was.
Now to look under there and see what/how to lube this thing and see if I can find anything that is bent or mishaped.
Name:	ImageUploadedByForest River Forums1403650533.791595.jpg
Old 06-24-2014, 05:58 PM   #40
It took some force but they popped out and then the crank turned easily.
electric, jacks
