Old 06-24-2014, 11:33 AM   #1
Fulltime family RVer
Electric rear stabilizer jacks - stop immediately
My rear jacks worked on Friday and Saturday but stopped working on Sunday. I'm trying to lower my electric rear stabilizer jacks. They make noise like they're going to work, lurch and then stop. The switch is then dead for some period of time (I'm assuming a fuse is automatically resetting). The jacks aren't lowering at all.
I've verified that the t-bolts on my JT StrongArms knockoffs are not tight.
I have this manual that wmtire posted a long while ago:
http://manuals.heartlandowners.org/E...lizer_Jack.pdf
I'm going to go through the troubleshooting steps and see what I can see. I'm also thinking of disconnecting my JT's from the electric stabilizers to see if they're binding things up in some way.
I'm open to other ideas.
Old 06-24-2014, 11:37 AM   #2
fonzie's Avatar
Try to move them manually first and electric again..... Also most likey you have auto-rest mini-breaker behind wall where your switch....(picture form Herk library)
Fonzie
Old 06-24-2014, 02:52 PM   #3
I'm willing to bet dollars to donuts that we have that exact setup. The auto-reset breaker seems to be exactly what is happening. My question is "why"/"what's binding it"? (It's worked flawlessly since new in July 2012.)
I'll try them manually.
Old 06-24-2014, 02:55 PM   #4
fonzie's Avatar
It might just be "jammed" little overtravel, too long on the push button......you'll see..and I would lubricate it again even if you have done in a few months ago.
Fonzie
Old 06-24-2014, 02:56 PM   #5
Durr... lubricate it? I haven't....
Old 06-24-2014, 03:00 PM   #6
Timex's Avatar
Ah Hah! Ever heard of the Tin Man?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-24-2014, 03:15 PM   #7
fonzie's Avatar
I know in the service manual it says not to lubricate components, but I do and use a dry silicone lubricant as posted below.
Blaster 11 oz. Dry Lube Silicone Lubricant-16-SL at The Home Depot
Fonzie
Old 06-24-2014, 03:19 PM   #8
Timex's Avatar
Fonzie
Yamaha 3000iseb generator: : Eastern Ontario
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (0)
Hey Fonz, what's up with that? The year is over half gone!
Old 06-24-2014, 03:25 PM   #9
fonzie's Avatar
Actually forgot to update (done). Thanks. Leaving for my next trip on July 7th.....
Fonzie
Old 06-24-2014, 03:27 PM   #10
Timex's Avatar
electric, jacks
