Old 07-19-2016, 06:49 PM   #1
Electric stabilizer jack not working
Hello - This is my first post. Purchased Wildwood x-lite 254RLXL few months ago and after a few trips the front electric jack will only go up. When try to go down there is no sound. The manual crank works fine so nothing is binding. Both switch and remote does same thing. I can take it to the dealer and get it fixed but wondering if this could be a re-occurring problem with this 2017 model? Could I have caused the failure?
thanks
wildwood2017 is offline   Reply With Quote
Old 07-20-2016, 10:05 AM   #2
Head Rambler
It's odd that the local switch and remote do the same thing.
If it works at all then the fuses are good.
Both the switch and remote reverse power to the motor to get it to raise or lower so it points to the motor being good.
Have you checked the wires on the back of the switch for loose connections?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-20-2016, 11:55 AM   #3
I played with wires and motor and does not act like intermentant. Something must have happened inside the motor? Because of year warranty I will wait awhile before taking into dealer for fix. Closest dealer a few hours away.
Thanks for the reply.
Old 07-20-2016, 12:03 PM   #4
Head Rambler
Does the motor have two wires or three wires going into it?
Gotta go campin!
Old 07-20-2016, 12:56 PM   #5
Wires are well insulated so can not tell.
Old 07-20-2016, 01:05 PM   #6
I believe a few folks have had the control board act up. Disconnect your battery for a few minutes and try it again.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 07-20-2016, 02:00 PM   #7
tried bat disconnect and did not fix. Jack goes up but not down. Nice try.
Old 07-20-2016, 03:15 PM   #8
if motor works in 1 direction the problem must be the switch-the switch changes polarity which reverses the direction of travel
danandmillie is offline   Reply With Quote
Old 07-20-2016, 03:56 PM   #9
remote does the same thing as switch
Old 07-20-2016, 04:02 PM   #10
Head Rambler
It almost sounds like the remote and local switch are wired to the same relays and that's where the problem is.
Gotta go campin!
electric
