Old 06-30-2016, 03:43 PM   #1
Electric stabilizer stuck in up position
The front electric stabilizer on my Rockwood signature ultralight is stuck in the up position.
The problem is not the motor. I removed the motor and it is working fine.
I cannot lower the stabilizer manually.
Any idea as to what to look at first?
Thanks.
johnsent is offline   Reply With Quote
Old 06-30-2016, 03:51 PM   #2
Pickin' & Campin'
Shear pin on the drive bar?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-30-2016, 03:53 PM   #3
Dont know.
When I try manually it will not turn at all.
Nothing unisual happened when used last week.
Old 06-30-2016, 03:55 PM   #4
Pickin' & Campin'
I've seen the pin snap when retracted all the way.
One of the reasons I marked mine and leave them down about an inch.
Old 06-30-2016, 04:05 PM   #5
If a snapped pin could cause a jam, can you describe where I should look? I aint got no idea.
And thanks for the quick replies.
Old 06-30-2016, 04:23 PM   #6
fonzie's Avatar
Take a crow bar and pry both leg free from each end, then try your electric again.....when bringing stabilizers up, a lot of people jam them tight and then these will not come down......
Fonzie
Old 06-30-2016, 04:25 PM   #7
Thanks much. Will try in the morning. Having happy hour on the porch now.
Thanks again
electric
