Old 09-01-2015, 03:30 PM   #11
Battery cut-off switch?
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 09-01-2015, 05:09 PM   #12
Half the problem
My problem is all most the same, my front stabilizers work but not the rear I have tried to locate the fuse but no luck so far. I have a 2011Rockwood signature ultra lite model 8317RKSS. Any idea where that fuse is locate?
Virginia Rocker is offline   Reply With Quote
Old 09-01-2015, 05:36 PM   #13
nomad297's Avatar
Did you get it worked out? If so, would you care to share with us?
Bruce
nomad297 is online now   Reply With Quote
Old 09-01-2015, 05:50 PM   #14
dannyabear's Avatar
The fuse is most likely located under the tongue near the battery
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 09-01-2015, 06:04 PM   #15
B and B's Avatar
In the Rockwood 8289 WS Fifth Wheel the reset-able circuit breaker is located behind the switch in the back. To gain access you have to take the cabinet apart.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-01-2015, 07:44 PM   #16
So I tried the remote today (didn't have AAA batteries this weekend) and it worked. Now I have to see if the switches on the wall work. Thank you everybody for all the responses! I'm sure I'll have plenty more questions.
pjpoppins is offline   Reply With Quote
Old 09-02-2015, 04:17 PM   #17
Ok so the remote works but the switches on the outside wall don't. Makes me think nothing to do with the battery but something else?
Old 09-03-2015, 09:47 AM   #18
Head Rambler
I had a similar issue with the landing gear on our RV. It turned out to be a fuse near the battery had blown. Since the remote feed is separate from the manual switch, the remote would operate them but the manual switch wouldn't.
P.S. I found a loose connection on the Short-Stop breaker, and that's what was causing the fuses to blow.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
electric, stabilizers
