Old 08-31-2015, 09:25 AM   #1
Electric stabilizers won't work
2015 Wildwood X-lite 262BHXL. Pulled into our site this weekend and the stabilizers won't go down. Both front and rear. No sound. Battery is fully charged and electric jack works. Thinking a fuse or something? Found some info on other sites but does anybody have an idea? Thanks.
pjpoppins is offline   Reply With Quote
Old 08-31-2015, 09:47 AM   #2
TURBS's Avatar
Check the current limiting circuit breaker by your battery, normally resetable.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-31-2015, 11:02 AM   #3
fonzie's Avatar
Check for burnt fuse in distribution panel visually....don't rely on red led. Another way to check is to press electric stabilizer switch (up or down) and have someone check distribution panel at same time, if red led lights up, then that fuse is burnt open.
Fonzie
Old 08-31-2015, 01:16 PM   #4
What does the current limiting circuit breaker look like? Is that under the tongue?
It seems like I found another fuse panel hidden once but now I have no clue (new to this so slowly learning). The main fuse panel under the the bunk has nothing labeled for the battery.
Old 08-31-2015, 01:25 PM   #5
TURBS's Avatar
Follow your positive battery cable from your battery down under camper.
TURBS
2011 32bhok Sabre
Old 08-31-2015, 01:45 PM   #6
Great thank you I'll check for that later.
Old 08-31-2015, 02:04 PM   #7
If your unit came with the remote control and it was used on the stabilizers, try using the remote to extend them. Sometimes the remote and control panel do not "talk" to each other. Just a thought.........................
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 08-31-2015, 02:08 PM   #8
Head Rambler
Just had one of those trip and not reset. Had to replace it. The local auto parts store had the correct one in stock. About $4.
Gotta go campin!
Old 09-01-2015, 12:12 PM   #9
Stabilizers dont work
Do you have the remote control feature? On our 27RLS I had incorrectly raised when they were full up, it blew a fuse at the "MUX" box that disabled the switches on the body (the remote function worked?) replaced the 20 amp fuse and all is well. BTW the MUX controller box w/fuses was located under the refer.
Burk
Burk is offline   Reply With Quote
Old 09-01-2015, 12:26 PM   #10
We had that problem on our 5th wheel and there was a tiny fuse in a wire on the wall behind the battery in the front storage compartment that we never would have found if the service manager didn't tell us about it.
CLewis is offline   Reply With Quote
electric, stabilizers
