Old 05-30-2015, 12:47 PM   #11
Crockett's Avatar
Ive found if you bathe the entire circuit in alcohol and dry ice to the temp of -197F that you can run both the AC and the WH on 110.
Thats for you Bob...
Crockett is offline   Reply With Quote
Old 05-30-2015, 02:19 PM   #12
People, remember that the engineers who designed the h2o heatee put the switch there for areason. It forces you to be cognicent when there is power to your heater and that you should have WATER IN IT! A simple momentary release of the pressure valve gives you positive feedback so you don't run the risk of burning your element out.
glfillion is offline   Reply With Quote
Old 05-30-2015, 02:46 PM   #13
Crockett's Avatar
Good point. You turn that switch on with your anode rod laying there staring at you, you deserve to lose an element!
Old 05-30-2015, 07:23 PM   #14
Keep in mind as posted on other similar posts that unless specifically switch rated the circuit breakers are not meant to be used as a switch. It may last longer than you and I , but just FYI.
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
electric, heater, water, water heater
