Old 07-07-2011, 03:10 PM   #1
electrical diagram
Where might I find an elecrical diagram-schematic for my 2007 22ft sierra sport by forest river?
sparks60 is offline   Reply With Quote
Old 07-08-2011, 08:11 AM   #2
Herk7769's Avatar
Good luck with that.
In my search for a schematic for my Flagstaff, I went up the dealer -> manufacturer chain with no luck.
As I have done much wire tracing in the camper I have discovered why I have been fruitless in my search. There is no such thing at the manufacturer either. It seems that everything is "home run" and the wires are fed from big spools of the same color wire. The only difference I found was in gauge (usually (not always) different colors for different gauges) so tracing wires is a crap shoot.
Someone posted a wiring diagram for a 30TS that should get you started. I attached it (but it is not for my camper).
HAM CALLSIGN - KC3FFW
Old 09-01-2011, 09:15 PM   #3
Just picked up 1999 Forest River 26ft Flagstaff ds RV and need to find fuses/breakers...no tail lights (clearance lights work) and slide out won't work. Any info would be appreciated.
Dmaxey is offline   Reply With Quote
Old 09-01-2011, 09:21 PM   #4
TURBS's Avatar
look for your convertor thats where they are !
but most clearance lights do not run through your camper fuse panel just through your truck.
Old 09-01-2011, 09:23 PM   #5
TURBS's Avatar
look for something similar to this
Old 09-01-2011, 09:25 PM   #6
Awesome, thanks for the quick response.
Old 09-01-2011, 09:31 PM   #7
TURBS's Avatar
your welcome !!
by the way on my old flagstaff there was a wiring junction box just under the front of the camper check there for a loose wire . just follow the cord back .
by the way what kind year make and model is your truck ?
on my silverado there are separate fuses for a towed camper than your actual truck .
So if a running light fuse in my truck for the camper tail lights blow my truck tail lights still work !
Old 09-01-2011, 10:16 PM   #8
Herk7769's Avatar
Look for a 30 amp blade type fuse for your slide located within 18 inches of the battery.
The Tail lights are powered through a fuse in the truck's circuitry. Check for power at the socket.
If the power is available at the truck, check for a bad connection in the trailer's plug.
Name:	Connector Pin Out.gif
