Old 06-19-2011, 03:37 PM   #11
Originally Posted by buzzards27
Not sure what power center you have, on mine there are two 40 amp fuses, if you have those check them. The easiest way the find the problem is with a multimeter. Check your battery first and work your way toward the dead circuits. Red test probe on the power terminal (positive), usually red and the black test probe on the negative terminal.
Where are these two usually located?
Gus976 is offline   Reply With Quote
Old 06-19-2011, 03:39 PM   #12
Originally Posted by bikendan
first, since your issue may be unique to popups/tent trailers, you should post a similar question in the Tent Camper section here at FRF.
from what i remember, our popup lights wouldn't work unless we flipped the sink counter up onto a white plunger. by pushing it down, it connected the lights and inside stuff.
you may have a similar switch that's not working.
it's basically a kill switch.
Excellent idea...just check....looks fine. Thanks for the info though.
Old 06-19-2011, 06:37 PM   #13
RV Newbie
buzzards27's Avatar
For our WFCO 8955 power center they are on the low voltage circuit board to the left of the the fuses for the branch circuits.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 06-20-2011, 09:03 AM   #14
I have a 2004 georgetown ,there is a fuse box located intne bedroom, I can't find any guide for that box there are about 18-20 15 amp fuses I have lights that do not work inthe living room, but can't find what fuse goes to what HELP
orend is offline   Reply With Quote
Old 06-20-2011, 09:19 AM   #15
Gus976, I think I would check on that switch on the galley if yours has that, as my Coleman/Fleetwood pop up that I owned had that same setup, and I had to replace that switch, because it went bad, and I had the same results; the outside light would work, but nothing inside. You should have some type of button or kill switch on there. Also, on another Coleman I had, the wires got pinched where the top closes down on the bottom section, and ended up breaking the wire inside of the sheathing, where I really couldn't see it! My neighbor found that for me! So, my suggestion is to check those connections, probably there lies your issues. Good luck, Randy
Old 06-20-2011, 10:42 AM   #16
Herk7769's Avatar
My money is on some variation of Acableguy06, bikendan, and 08flagvlite's advice. Could also be a corroded connection on the back side of that switch. Simplest answer that explains the facts is always right
(Occam's Razor).
Old 06-22-2011, 09:09 PM   #17
Thanks for the info...will play with it this weekend and let everyone know the outcome!
Thank you all again!!
Old 06-22-2011, 10:21 PM   #18
I agree with everyone above. Im leading towards a bad switch, loose connection, or a weak breaker.
2008 Rockwood 8281ss
2006 Dodge Ram Mega Cab Hemi
Reese 15k Slider
mikegp1 is offline   Reply With Quote
