Electrical issues 2006 Wildwood
Need some help if at all possible! Just recently when plugged in to 110 and I turn one light on all is good, if I turn two lights on the lights go dim and the CO alarm chirps. Also our slide will not move unless it is hooked up to the battery, if only plugged into the 110 the slide won't move and again the CO alarm chirps. If I have the battery connected no issues with turning up to 10 lights on. Is it a bad inverter or converter or what?
