Old 03-28-2008, 07:03 PM   #1
Grey Stray's Avatar
Electrical problems on new TT?
I'll try to make this simple.
I have an '08 Salem LA. I intend on replacing all of the exterior lighting with LED lights. I have replaced the rear brake lights(here starts the problem). The trailer was plugged into my truck but not secured via the hitch. The tail/brake lights were barely visible. These lights will blind you if it is hooked up directly to a battery. Why wouldnt they be that bright wired to the trailer. I used the common ground wire from the trailer just like the stock lights did. HELP!!!!!!!!!!!
2010 Sierra 355QBQ
2011 Chevy CC LB Dually 3500
2006 Dodge CC LB Dually 3500 - absolute garbage- sold
2 healthy kids
1 fat boxer
and a beautiful wife......my life is good!
Grey Stray is offline   Reply With Quote
Old 03-28-2008, 08:34 PM   #2
i would say if you hook it too the truck it will get a better ground. I have a little electrical experience and when we have a floating neutral on AC your lights or whatever is attached is only getting aboout 80V enough to light it but not enough to fully light it.
DW of 12 yrs 6yr old girl, Twin 9yr old girls, 9yr Old boy (10 months between the Three)
2010 Suburban 1500
2006 Sea Ray 185 sport
On the hunt for a new travel trailer
wvsteve is offline   Reply With Quote
Old 03-28-2008, 09:11 PM   #3
welshman599's Avatar
Send a message via MSN to welshman599
Hmmm, were the original lights also dim if you were hooked up exactly the same way? And did the LEDs brighten properly when the brakes were applied?
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 03-29-2008, 10:25 AM   #4
I think I'd go with wvsteve on this one. Sounds like a weak/floating/intermittent ground. The lights and pretty much everything on your trailer are grounded to the frame. Your trucks power is grounded to the motor and frame of the truck. You are providing power from your truck to a separate vehicle and the only common ground is via a small wire through a connector that probably has some corrosion albeit minor as it does work. DC contrary to popular belief flows from negative - to positive + (yeah I know techs are taught pos + to neg -, it's easier that way) so a good ground is especially important. And since the ground on both vehicles is the largest chunks of metal, when they are only connected via a small wire it just isn't enough.
aintgotnun is offline   Reply With Quote
