Old 04-21-2011, 01:27 PM   #1
emegency light (tail light not working)
2010 popup , right emegency and turn signal not working . Bulb good
skip1955 is offline   Reply With Quote
Old 04-21-2011, 01:45 PM   #2
Wildwood1's Avatar
test your tow vehicle first to see power is getting there, then make sure you have a good clean trailer plug connection, after that i would check the bulb socket for power!! if that dont work start wiggling and tugging on the wiring to see if you can get a response!! if the problem gets too deep i'd bring it to your dealer cause i would think its under warranty.
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
Wildwood1 is offline   Reply With Quote
Old 04-21-2011, 04:55 PM   #3
jimh's Avatar
emergency light (tail light not working)
if u pull the bulb and get voltage but the bulb doesn't light, try the above, first. on mine, the trailer circuit had been spliced in using those nice looking blue self cutting splicers. my problem was in that area. if u wiggle that, it should restore contact until u can redo them.
most of the time, its going to be as stated by wildwood1. WD 40 is an excellent cleaner for electrical contacts.
jimh is offline   Reply With Quote
