Old 08-31-2011, 02:47 AM   #11
flyrotor's Avatar
Originally Posted by prof_fate View Post
Remember to attach the end to the TV, NOT the chain hook. If the hook comes off the TV the brake cable will fall off too - and not activate the brakes as it should in such a situation. I picked up a carribiner at lowes like the link shows for the coiled wire.
To add to this, the breakaway cable should also be shorter than the chains, thus if the trailer ever leaves the ball, the breakaway will activate the brakes BEFORE the chains fail, a long cable is counterintuitive and will only activate if the ball disconnects and both chains fail. Be careful with the coil type cables as they appear to be connected correctly when in reality they may be too long.
flyrotor is offline   Reply With Quote
Old 08-31-2011, 05:08 AM   #12
I agree 100%! Youroo!!
brakes
