Old 08-29-2011, 07:59 PM   #1
Emergency Trailer Brake cable-
Hey Forum...
First off.. a little appreciation to all those who have helped thousand of us kick start our RV adventures... Im a newbie and will gladly reciprocate with advice as my experience grows but until then, hanks in advance for your help.
So the question is in regards to the aircraft cable that runs from the front of the hitch to a simple plug switch near the front of the trailer that (I believe) helps to activate your brakes in an emergency separation. I noticed yesterday that my cable had sheared off somehow (I believe from dragging on the ground???)... YIKES!
Well I need to replace it and while I know where it connects to the little plastic plug / switch, Im not exactly sure where it connected in the front. I believe it was tied into a loop and connected / interwoven through one of the safety chains and then looped along with one of the safety chain clips that connect to the tow vehicle on either the left or right of the actual hitch.
Do I have this correct? Seems like a simple fix with AC cable and a couple of crimp clips...
Just want to do it right, since it's an important safety feature.
Thanks again for any responses...
Patrick
pmahoney is offline   Reply With Quote
Old 08-29-2011, 08:01 PM   #2
TURBS's Avatar
your correct ! i had mine looped through my chain hook .
Old 08-29-2011, 08:07 PM   #3
Steve38's Avatar
I like this idea..
Fastway Trailer Products - Fastway Zip Breakaway Cable & Switch
Steve38 is offline   Reply With Quote
Old 08-29-2011, 08:15 PM   #4
Thanks Guys
Appreciate the advice....
Old 08-29-2011, 08:43 PM   #5
Old car's Avatar
Mine did the same thing but I had enough of the cable to make a new loop, bought a crimp ferrule at the hardware store and I slip it over the ball before lowering the trailer for final hookup. There appears to be enough space where the contact point of the hitch and ball won't pinch the cable.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 08-29-2011, 08:53 PM   #6
tomjsas's Avatar
I have one of the fastway cables mentioned above and love it. The dealer put in on free of charge (both for the cable and labor) since we were good customers so not sure how it was actually attached. So much easier to deal with than the old wire cable!
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 08-29-2011, 09:14 PM   #7
new style coiled wire safety
I think Im going to take the advice above for this weekend and just recrimp with new ferrule until I can purchase one of those "high tech" coiled cable deals...
Thanks again for all your replies to the original posting.
Old 08-30-2011, 12:41 AM   #8
Dismember
TimeFurnace's Avatar
I have an excessively long breakaway cable. The way I keep it from dragging on the ground is to give it four to five twists before connecting it. The twists cause the breakaway cable to coil up upon itself. It then lays nicely atop the safety chains with little chance to droop to the ground. Consider it a poor-man's Fastway cable.
2012 Wildwood 24TBSS
2x80W Solar Panels, Morningstar MPPT Controller, Xantrex LinkLite Battery Monitor, Xantrex ProWatt 2000 Inverter
2010 Toyota Tundra DoubleCab 5.7L 4X4
TimeFurnace is offline   Reply With Quote
Old 08-30-2011, 09:05 AM   #9
prof_fate's Avatar
Remember to attach the end to the TV, NOT the chain hook. If the hook comes off the TV the brake cable will fall off too - and not activate the brakes as it should in such a situation. I picked up a carribiner at lowes like the link shows for the coiled wire.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 08-30-2011, 10:18 AM   #10
understanding the details, probably makes better sense to connect to some part of the TV (not ball of hitch b/c it too, although highly unprobably, can become separated from TV).
Looking to connect into the actual part where safety cables connect underneath TV (steel). problem is it will take a little longer to do since 95% of that available space inside the opening in that plate is taken up with the safety chain hook.
I'll find a way... im sure...
Thanks for all the feedback, suggestions. much appreciated
brakes
