05-01-2011, 02:15 PM
Ever Hear of this Happening? Smoke alarm question
First time out in brand spanking new RV. Camped in the White Mountains National Forest in New Hampshire. Came to bed time, set the thermostadt to 55 degrees and went to sleep. 2:00 AM the furnace comes on. 2:02 AM the smoke alarm comes on. Not a pretty sight me hopping up to shut down the furnace and open the roof vents and turn on the fans. The unit was not filled with smoke, no odors I couldn't believe were just because 'new'. Aired out by 2:10, went back to sleep as the interior temperature approached 38 degrees. Turned thermostadt back on, same results, same comic episode.
Tried again at 7 AM, same. Got home after 250 mile drive. Same.
05-01-2011, 02:34 PM
Villa Estate 392FLFB
id assume its from either the crap they leave in the vents or something is in the furnace that should not be there. Dealer time!!
One state/province at a time!
05-01-2011, 02:51 PM
Sounds like it could be a defective smoke detector that is sensitive to the heat or possibly the dust that the furnace stirred up when it went on. I would replace the smoke detector first and see what happens.
Tom and Margaret
2014 Berkshire 390bh-60
05-01-2011, 02:53 PM
your dealer should have told you to run the furnace for awhile, before you went out.
this should be standard recommendations, since the new furnace needs to burn off residues.
i was told this by my dealer and it's discussed many times on RV forums.
what you experienced is common for new owners that don't do this.
by the way, next time you should post this type of question in the General Tech and Repair section here at FRF. not under the Travel Chat section.
you'll get more responses for this type of issue.
05-01-2011, 02:58 PM
camping
you also want to burn off the oven. ours smoked really good. I was lucky enough to do it at my house when I was working on the camper, I took the batteries out of the smoke detectors and turned on the bath fan.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
05-01-2011, 03:58 PM
Thats normal - we had the same thing happen and I should have thought of it. I work for an HVAC company and everytime we install a new furnace or replace the heat exchanger in one, we have to burn off the heat exchanger. The heat exchanger when it manufactured has some oil residue on it from the manufaturing process. When it gets hot it burns off slowly. Open all your windows and pull the smoke detector and crank the stat and run for a while after the smoke stops.
05-01-2011, 04:10 PM
Wanna Be Camper
Dealer have burnt the furnace in for an hour or so to burn oil out of the furnace. Part of the PDI we pay for. Our Edgewater when we got it the dealer forgot and it scared the bejeeze out of us. I made sure and asked them about it when we did the walkthrough on the V-Lite and they showed us it is part of the check list for them to do.
John & Deb
2011 Flagstaff V-Lite 30WRLS
05-01-2011, 04:24 PM
Yep, run furnace and oven for a while with windows open. When we took our unit home last spring we ran the furnace and oven to clean out the junk. Are you sure its the smoke detector and not the CO2 detector going off?
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
05-01-2011, 05:09 PM
Yeah they left a lot of crap in our vents to but nothing cough on fire
05-01-2011, 07:01 PM
Thanks everyone! I opened all the windows, started all the fans, set the oven to 500 degrees (more like a kiln), and set the thermostadt to 83 degrees. The smoke detector chirped a few times and fell silent after 10 minutes. After 40 minutes I started closing windows and shutting down the fans. Left the furnace and oven on for an additional 20 minutes and not a peep. Shut everything down and repeated an hour later. No more smoke alarms! Won't experience this again until my wife makes her famous casserole.
Saved me bringing the RV back to the dealer and all the drop off pick up hassle.
05-01-2011, 08:45 PM
i would definitely have a conversation with the dealer about not be advised of this practice.
makes you wonder what else they left out.
05-01-2011, 09:58 PM
am glad I ran across this thread - I do not think my furnace and stove have been so called "burned in" so looks like I will be doing this to make sure I dont have this issue.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-01-2011, 10:12 PM
I'm glad it was posted also. Now I'll be requesting that our dealer do this prior to our pick up date.
Rockwood 8293RKSS
