Old 10-07-2018, 09:06 AM   #21
Denver To Yuma In 90 Days
I wonder if there is a GFI box somewhere...either in the kitchen or in the bathroom.
When mine kicks it takes out the bathroom, kitchen and entertainment center.
Might try resetting that to see if maybe it is just stuck close to the verge of kicking out.
My GFI box is in the bathroom.
JohnD10 is offline   Reply With Quote
Old 10-07-2018, 10:27 AM   #22
microwaves are not in the gfci circuit . check connections in the breaker panel make sure all lugs are tight , if you have a built in generator then check the connection inn the transfer switch .
MR.M is offline   Reply With Quote
Old 10-07-2018, 10:53 AM   #23
That depends how it's wired. Many TT/MH are wired differently. Heck, even in one of my houses the fridge is on a GFI.
babock is offline   Reply With Quote
Old 10-07-2018, 11:33 AM   #24
bedubya's Avatar
But a GFCI receptacle does not reset by itself.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
bedubya is offline   Reply With Quote
Old 10-07-2018, 11:42 AM   #25
Mine is...as was my previous 2013 TT.
Old 10-07-2018, 11:43 AM   #26
I know...which is why I suggested resetting it by pushing the red button it the middle between the outlets.
Old 10-07-2018, 11:44 AM   #27
But one that has flakey contacters may have this problem.
Old 10-07-2018, 07:37 PM   #28
Jfr
Hello All! Thank you so much for trying to help us out. Here at Searsport Shores campground one of my neighbor campers that I met came over with his tester. I am getting 120 from the pedestal to the end of my plug. However when we test outlets I'm getting between 70 and 90. Might explain why it took almost two hours for a pot of coffee. If we turn off the inverter breaker and one other breaker (not sure what it is) we r getting 120 to everything else. Once the breakers in question r turned back on all others r getting between 70 and 90. We leave tomorrow to head home. Will contact the dealer as our rig is 30 days old as of today. Again thank you all for trying to help us. Wanted to let you know what's been going on.
John and Diana
Jfr is offline   Reply With Quote
Old 10-07-2018, 07:44 PM   #29
Good idea to let the dealer resolve it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 10-07-2018, 08:18 PM   #30
Jfr
Thank u so much for responding. Think we narrowed down the issue but will need to let the dealer fix it. Only getting between 70 and 90 volts inside unless two breakers r turned off, one is the inverter. Assuming they stand behind it as the camper is 30 days old as of today. Thanks again for trying to help.
John and Diana
Old 10-07-2018, 08:50 PM   #31
house is different . many circuits in a house in fact most are protected by gfi breakers are arch fault breakers . tt's will use gfci on all outlets which in most is one circuit the microwave is on it's own breaker and not gfci protected and not tied into that gfci outlet
Old 10-07-2018, 10:22 PM   #32
Lol...hope you mean arc fault! No arc fault breakers in my house.
Old 10-08-2018, 01:56 PM   #33
Commercial Member
ES_FR's Avatar
John and Diana (Jfr),
Please accept our sincerest apologies for the issues and any inconveniences as a result of your concerns with your Grey Wolf. If this issue is unresolved, please contact Mikala Yoder in our service department by visiting this personalized link: Forest River RV Direct Service Contact - Forest River, Inc..
In order to resolve your concerns as quickly as possible, please use this link to outline your concerns and Mikala Yoder will respond within 24 hours.
Thank you,
Forest River
ES_FR is offline   Reply With Quote
Old 10-08-2018, 03:43 PM   #34
that's right arc fault and they are used in many homes though . i got rid of all the ones in my house , very high failure rate
Old 10-08-2018, 04:01 PM   #35
llr
Jfr, Is this the only campground this has happened at?
If so it could still be a campground issue. How are you checking the voltage at the pedestal? if it is without load it would be good as you are seeing some good voltage in the camper without load.
Does the pedestal have multiple outlets, 15/30/50 if so check the voltage at the other outlets when you have the low voltage in the camper. If these are all good or don't exist try with your plug just a tiny bit out of the pedestal outlet so the camper works and you can get a meter to the prongs. If any of these show an issue at the pedestal it is the campground issue.
from your description the breakers you are turning off are not the issue but a bad connection somewhere else, they are just removing the load.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 10-08-2018, 04:17 PM   #36
Not sure why you continue to argue with many of us when we say that when our GFI kicks it takes out our microwaves.
BECAUSE IT DOES!
Matter of fact, that GFI will take out the whole kitchen and entertainment center when it pops (except lights, of course)!
And my previous TT...did the same thing!
Old 10-11-2018, 06:12 PM   #37
We also have this problem with the fireplace on we can’t use the microwave turn fire place off to use microwave we had this in to fix both at the dealership. And factory they said live with it both circuit are connected
RAYSR is offline   Reply With Quote
Old 10-11-2018, 06:24 PM   #38
Mr Towed's Avatar
This would make more sense if you DID have some kind of EMS, but i'm wondering if a neighboring camper has an AC unit that is kicking on with a large inrush, maybe a motor/compressor that is going bad, thereby causing a momentary voltage drop. This might cause your AC items to reset briefly.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline   Reply With Quote
Old 10-11-2018, 08:23 PM   #39
This is on going no matter where camping happens all the time manufacturers problem that we deal with not a big problem
Old 10-11-2018, 08:34 PM   #40
Mr Towed's Avatar
Not sure if that was in reply to my post the OP stated this was their first trip out so they can't rule out the power at the camp ground. Your issue sounds different than theirs, if I understand correctly.
microwave, power
